Post
by Gannon » Mon Sep 19, 2011 11:36 pm
Taken from the BC/BF Gen1 Liberty FSM
Why is the right hand side shaft 10mm longer and 2.8mm larger in diameter at one end, compared to the left side?
Also, why is the 2.0 turbo and 2.2L shafts 27mm shorter than the 1.8 and 2.0L non turbo?
The track should be the same, as should the width of the gearbox. Why the difference?
- ej shafts.jpg (98.67 KiB) Viewed 2521 times
