EA82 Oil Pump Priming
Hey Guys,
I have rebuilt an EA82 carby and have just got it running today and it was ticking its nuts off which was expected but it didnt stop and got hot pretty quick..
I have a nasty feeling that the oil pump isnt doing its job and want know how to check if its working or how to prime the oil pump?
Any help would be great!
Wagonman
Wagonman
Did the oil pressure light go out?
I've got an aftermarket oil pressure sender on there at the moment that i haven't hooked up yet.. I was gonna hook that up tomorrow with the temp guage aswell, but yeah good point that would definitely tell me if its working!
I guess in theory you could also take the oil filter or oil pressure sender off and see if oil squirts out right?
The oil pump was sitting dry for about 3-4 months after rebuilding it and i've heard since then that they need something to push against to be able to start pumping when they are dry but i dont know if this is true for the EA82.
Just figuring out what to do next before i start it again and possibly destroy it!
Not much you can do really other than what Steptoe has said. Just make sure it has some oil on the moving parts before you install it, only needs a smear to help lubricate things...
Always a nasty feeling knowing there's no oil in the oil pump on that first start up after rebuilding...
I remember on my EA82 rebuild before installing the cambelt I filled the engine with the usual amount of oil and ran the old cam belt on the oil pump, powering it with an electric drill. I did this for a few minutes and left it at that.
- onethousandhp
The other day i got around to priming the oil pump. I got piece of vacuum hose i think and stuck it on the end of a little oil squirty can and shoved that hose as far down the offset hole next to the oil fliter thread and squirted a few times and then put the filter back and started it.. and it was all sweet.
I hooked up the oil pressure guage to check it and it read 50-60psi. Anyone have anything to compare that with?
She's still ticking like crazy but its alot better, i reckon i have to take it for a good spin and another oil change and hopefully it'll sort itself out. I didnt replace the lash adjusters when i rebuilt it cos they werent noisey before and there wasnt much movement in them when i took them out so they should be alright.
Wagonman
Wagonman
Thanks for your input guys.. It's a good thing i got big round trip of the Southwest coming up soon then, that should sort her out hopefully. But first i have negative camber issue on the on RHR wheel to fix (hub is bent i think)and I have no brake pedal pressure to sort out in the next few weekends.
She's getting there though.
cheers.
wagonman.
cheers.
wagonman.
better come in and correct things. EA81 was easy to prime by shoving a rubber fuel or trans cooler hose fitted with a funnel in the off-set hole of the oil pump with the filter off - not the threaded hole.
The EA82 I did the other day I discovered the oil pump offset hole goes up hill first and does not take oil in same way with hose and funnel.
Simply added the oil to full in sump, with spark plugs out turned engine over by hand on the cranks 22mm bolt with hand ratchet with oil filter off until it spilled out - drain dish is a good idea too
Then fitted oil filter and continued by hand to fill filter and prime oil galleries.
