ea82 l series timing belts
My subie had 250 000 on it when I got it, only done another 5000 more now.
Im not sure about the condition of the timing belts.
Can you tell by looking at them ?
If a belt breaks, does it damage the engine ?
- TOONGA
Visual inspection can be done by removing the outer timing covers and inspecting the belts look for wear cracks in the belts, missing teeth etc.
if you have never done a set of timing belts since you have owned the vehicle I wouldn't wait until you were trapped somewhere by a broken belt. might pay to do the water pump, tensioners and pulleys as well.
finally the EA82 is a non interference motor so you won't have problems (apart from it not running) if you break a belt.
