Air-cleaner ?????
Bronny
Air-cleaner ?????
Post by Bronny » Sat Mar 26, 2011 5:22 pm
The 2.5 i just bought has had the original air-box remooved and a K&N head put on:confused::confused: There are 4 vacume hoses just sitting there going no-where, Surely these hoses need vacume. Im'e after a air-box if anyone knows of one cheers.:( Bronny
Post by Gannon » Sat Mar 26, 2011 8:11 pm
What model?
Many subaru's had 2.5L engines, and although they were very similar, there are a few variations of air box's between models and years
Bronny
Post by Bronny » Sun Mar 27, 2011 9:52 am
Suparoo wrote:What model?
Ummm!! Right model??? On the compliance plate Model: BH9AK7R. It looks like the air box mounts at the back of the motor above transmision Its a 10/98 Heritage 2.5 AWD I was told its the same as the Liberty! Thanks.This is my first ever subaru.:-D
Post by Gannon » Sun Mar 27, 2011 11:32 am
Ah right-o
The hoses are around 10mm ID?
They are for PCV (positive crankcase ventilation) and dont really need vacuum, just somewhere to vent to.
There should only be 3 of them, one from each head, and then one from the rear left of the engine.
You could join them using 2 T pieces, with the 4th port being taken up and stuck into the pod filter.
A proper air box is still the best method
Bronny
Post by Bronny » Sun Mar 27, 2011 1:50 pm
Hi, I have all the airbox parts from the previous owner, has anyone a pic that shows the engine bay with it all connected up! Cheers Bronny.;)
Post by AlpineRaven » Mon Apr 18, 2011 6:24 am
BH - 3rd Generation 1998 model.
