Basically I'm building up David’s (D3V1L) brumby project. It has an ej20t with a wrx gearbox currently. I'm working on my own custom (and cheap) rear brake conversion at the moment and will post more on that later).
As I would like to eventually turn this into a 4wd like my old brumby, I’m stuck deciding on a gearbox set up. There would seem to be a couple of options for me:
1) Install an L series 5 speed box (I currently have one lying around).
2) Install a forester awd DR box (with viscous centre lsd)
3) Combine some kind of super box of the best worlds with awd and low range 4wd.
I’ve been told that the DR boxes are weaker than wrx boxes (due to fitting the DR set up inside the same casing making the gears smaller) but I was wondering how much stronger are the awd DR gearboxes than the L series ones?
I also noticed that the rear axles on a brumby are thicker than wrx ones?! Does this mean they were very conservative when designing the brumby/L series drive train?
Another point is that it would be a lot better for on road driving awd with an ej20t (although fwd may be the last option).
I understand the 4wd makes a difference off road but how good are the awd DR boxes off road?
Finally is there some kind of way to fit an open-or-locking centre diff into a forester box?
I’m sure a few people have come across these questions before
Marcus
