will it fit?
will it fit?
Hi; I have seen a clutch plate on ebay for a brumby $30, mine is an 89 L wagon; Will the brumby plate fit?
Quick answer no.
Just get a new one - this way you won't be pulling your L apart any sooner than you have to due to the clutch giving out again.poprock1 wrote:Hi; I have seen a clutch plate on ebay for a brumby $30, mine is an 89 L wagon; Will the brumby plate fit?
Plus a new clutch disc WILL be at maximum thickness, unlike something you could be buying on ebay...
- TOONGA
2 different size clutches 200mm and 225mm, 2 different spline sizes per clutch size 21 spline and 24 spline, but still won't work properly as Ive had this problem so has Guy when he put an L series flywheel into a brumby I think it was78sti wrote:Won't fit onto the gearbox input shaft - totally different.
L clutch.
Thanks guys; You are all correct. Rather than pay $130 for a new one I went to Budgewoi Spares (kurri branch) where they said they had one but still in car but if I was prepared to take the risk I could pull the motor out and see what it was like. They were quite surprised when I said ok; and 90minutes later I had a good clutch plate; 2 rear gas t/gate struts and various small items for $20 and they had an E82 on the ground ready for sale. Still chasing passenger side front park/blinker lens.;small or big amber section . It has one of each at the moment.
clutching at clutches.
if you are looking for an alternative, ring Jim Berry at Race Clutch. he will sort you out with a pro clutch that will do EXACTLY what you want, and he is THE ducks nuts when it comes to clutches. He made me a 4700lb clamp on a holden gemini diesel disc, it had as much clamp as a button clutch and was as easy to drive as a standard one.
