HELP! asap! Loose nut in xmember!
- ScubyRoo
HASLDNF ALSDKHF !!!LK ASJDF !
Almost finished the entire car read for road worthy inspection, and the third last fu*king bolt craps out.
It's the right (Drives side) front gearbox crossmember bolt, the one that goes into the chassis. Basically the nut in the body has broken free of whatever holds it there, so the bolt and nut are stuck together -- cannot undo, cannot do up... just spins or goes up and down the distance still to tighten when pushed up. It broke free at low torque half way up thread... i'm totally gutted.
How the hell to I get access to the nut??!?! I looked on my parts bomb... ripped up carpet and everything... it seems it is in its own little spot. Does it have to be cut out and a new section welded back in with a replaced nut?
Any help would be greately appreciated!
Thanks,
Owen.
Thanks,
Owen.
The Green Machine is up for sale . Lifted, bars, exhausts... View Gumtree ad
yah broken captive nut.
cut the bolt, then get a hole saw and try to get the nut out, once its out re-weld it to a piece of flat bar and weld the bit of flat bar to the body. Pain in the arse
Bugger - that is annoying isnt it!!! Mine one has the same problem!!! Did the same thing what alex did.Alex wrote:yah broken captive nut.
- ScubyRoo
Thanks for the suggestions guys - 78sti thanks for the idea, when I first read it I was thinking it sounded a bit epic!
I think Alex's idea sounds the least epic, will get onto it on the weekend when I have time again. AP you're right, it really is a pain in the arse - I've had to delay my rego inspection 2 weeks now, argh! Just want this car finished!
- d_generate
I had to do mine on the WRX a few months ago before I put it over the pits cos the thing knocked like hell, I spent a while measuring the right spot but in the end I drilled a small hole up from the bottom next to the bolt then attacked it with a 32mm hole saw from inside the footwell, turned out some cock had spun the thread out of the captive nut but luckily the bolt was long enough to put another nut on top so I just shoved one on and tightened the hell out of it.
I didn't bother covering the hole as I'll need to get to it if ever the box has to come out but it's pretty easy to get to so it shouldn't be too big a job for you.
yeah this is another good idea. Did it on my l-series. Like 5 times hahad_generate wrote:I had to do mine on the WRX a few months ago before I put it over the pits cos the thing knocked like hell, I spent a while measuring the right spot but in the end I drilled a small hole up from the bottom next to the bolt then attacked it with a 32mm hole saw from inside the footwell, turned out some cock had spun the thread out of the captive nut but luckily the bolt was long enough to put another nut on top so I just shoved one on and tightened the hell out of it.
