Spark Plugs
Spark Plugs
Hey Guys,
So I went to Repco today and went in to get some gear for a service. When they looked up for my 05 Impreza, the guy seemed confused which plugs, because the MY05 and MY04 have different numbers for each filter.
The My04 has Champion Golds and a couple of others $5.40 and the MY05 only has NGK Platniums $30. HE apparently couldn't work out the difference and sold me the Golds. (They were same length, same Thread, slightly different gap.)
Now before I go sticking them into mine, Is there a difference? Should I be worried and go back?
The better brand is the NGK (from what I've heard) my friend has the NGK Platniums and he strongly recommends them, the only downfall is the prices, but the quality is much better and you'll get better results. In my opinion I would go and swap them over to the NGK Plat.
Hope that helps.
Hope that helps.
Johnny T
88kw of fun waiting to happen
Johnny T
About 5 or 6 years ago I read a survey some testing mob had done on the best value for money/performance on spark plugs and the Champion Golds came out on top. I've used them since (on non turbo engines) and never once had an issue with them. Always check and set the gap to the vehicles specs They will never last as long as Platinum/Iridium plugs so make sure they are replaced at the recommend intervals.
