impreza diff gears into L-series diff
Hi, I have an impreza diff in my L-series at the moment from an auto (1997), and was wondering if I can put the gears from it into an L-series diff and then bolt that up?
Why cant you use whole housing from impreza in L series - straight swap?
The only difference would be the flange will be different.
The crown will not fit on L series centre as the bolts will require re-drilling/tapped as newer diff has different size bolts compared to l series (L series is smaller bolt holes).
![Image](http://i14.photobucket.com/albums/a313/tmerritt/PICT0927.jpg)
Well, the whole driveline (eng,box,tailshaft?,diff) is impreza, and the rear diff was a straight swap except for the driveshafts which had to have the inner cv joint race welded to the shaft (due to different splines). Now the inner joint has demolished itself and the only way is to either re-weld it all over again (not liking that idea and more expensive than i thought) or making up a custom shaft by re-splining (expensive! but at least I can re-place the joints easier).
If I could use the L-series diff, then the stock driveshafts can slot straight in (cheap), except that the gear ratios are obviously different to the awd box (I think 4.11? not sure).
AP: So how much effort or cash would it take to re-drill the holes and tap them? Possibly a home job? or professional needs to do it?
I wanna do this as cheaply as possible as I have a full stock L-series rear driveline/tailshaft sitting at home.
Also another idea put forward was to stick the male ends from the L-series diff into the Impreza diff (Is that even possible???)
cheers
cheers
I just did some reading up, and found out that only the EARLY lib/impreza diffs have male stubs coming out of the diff! And that my style of diff won't work with those shafts cos apparently it will then be too short and pull the cv joint out completely (which is exactly what happened to me).
So I might just look around for an old impreza or liberty diff with the gear ratio that I need, I think that may be the easiest way? Anybody got a list of what gears which diff came out with?
Yeah mate find out what ratio you need and i can ask a few guys i know that may have diff for you. Just bring a L rear cv and test if it fits on the diff first:)
Plus that would be easier for you as i need that tailshaft off the wreak remember??
LOL.
I'll check if i have an early Lib diff here, i think i do, and will test if the rear cv fits on:)
![Smile :)](./images/smilies/icon_smile.gif)
LOL.
![Image](http://i1259.photobucket.com/albums/ii547/guyph_01/b_zpsd4bf36a5.jpg)
working diff.Pav wrote:seagull, what do you mean by mechanical?
