welded lseries rear with 215r15 tyres
hey guys has anybody run a welded rear with tyres this big, will the cv's and axles be able to handle it ? ive run welded rear on standard tyres, but nothing this big.
cheers brenton
cheers brenton
If you have 215 (unknown height) 15" at the front and rear (all same size all around) it'll be ok, but you'll notice wear quicker in the rears.
Depends which subaru he has.. - What Subaru is it Brenton?vidler wrote:when your onroad, jack the drivers side rear wheel off the ground, punch out the roll pins and remove the cv shaft completely, then put it in before any offroad trips and you'll be right, makes no difference when removed on road because that wheel is free spinning
AH L series.. Fair enough... (if it was AWD then you'll damage the centre diff)brenton wrote:yeah sorry guys i know the trick with removing the axle onroad , i was more worried with full power hillclimbs etc offroad. it will be in a parttime 4wd lseries .
cheers brenton
Yep can be done if you removed the rear axle and use a wire to tie on or cable tie to prevent them popping out while off road. (I know El Freddo does this as well)
Vidler has first hand experience with full power hill climbs with a welded rear diff and exactly what it can do with rear driveshafts lol :P
I think he lifted the rear end off the ground right at the top of a hill and came down hard on one wheel - snapped one of the rear driveshafts clean in two!
He was running 14's with 27" tyres at the time I think.
EJ22 power.
L series with 5spd part time gearbox. The pic might be floating around somewhere.
EJ22 power.
EZ30 L series - Monsterwagon
Yeah definitely easy to keep a spare. As I recall, it was a difficult 4x4 trip the rest of the day in 3-wheel drive. it makes more of a difference than you'd expect.
Yeah, as AP says, I've used cable ties, nails, fencing wire etc to hold the shaft in while 4wd'n and have never had a problem with shafts coming off. The cable ties showed no signs of any sheering either.AlpineRaven wrote:Yep can be done if you removed the rear axle and use a wire to tie on or cable tie to prevent them popping out while off road. (I know El Freddo does this as well)
The L series power with both rears having traction will be fine - that's the idea of the welded rear end.
And +1 for taking a shaft out when on the black top - less hop-skipping/squealing noise and weird tyre wear pattern, even with only a bit of black top use, my rear tyres wore unevenly.
All the best with it - you'll love the welded rear end! Defenetly pack an extra shaft or two
you made a typo. its spelt and said - EJ22 POWAH!!!!!!AndrewT wrote: I think he lifted the rear end off the ground right at the top of a hill and came down hard on one wheel - snapped one of the rear driveshafts clean in two!
EJ22 power.
i used a welded diff with 29 inch tyres for a few trips. had no worries. seemed ok on the road too- but i usually took the shaft out. only went thru one rear cv shaft with it chirping 27s for almost 3 years
