Denso BOV
caboolture
Denso BOV
Post by caboolture » Sat Apr 11, 2009 1:40 am
Hello looking to change the plastic factory plummed back bov on a jdm 93 EJ20T. Are all factory bov the same rating as in psi. The boost guage is showing 14 psi with vos swith turned on. What other options have you used. Thanks Peter
1991 gx 3" lift 16" gt Forester alloys,215/65/16 outback struts and pedders raised springs, Turbo motor,gearbox,diff,brakes,bonnet etc now transplanted :D
Phizinza
Post by Phizinza » Sun Apr 12, 2009 3:04 pm
This reply deleted.
Love you guys, haha
Post by Gannon » Sun Apr 12, 2009 3:59 pm
The stock bov does its job nicely. Why do you want to change it?
It doesnt have a so called psi rating cos the moment there is more pressure in the big pipe than the in the vac line, it opens and redirects the air.
Aftermarket bovs are highly over rated and over marketed. The factory bov is put in place for one reason only... to keep the noise down on gear changes, aka... flutter
caboolture
Post by caboolture » Tue Apr 14, 2009 9:39 pm
Thanks for your info. The reason to change it is that it leaks boost and after maybe 16 years it needs replacing. I went to the local Subaru dealer and he advises Subaru don't have them anymore. I do want to buy a new factory bov so if you know where a new can be bought let me know. Cheers Peter
Post by Gannon » Tue Apr 14, 2009 10:22 pm
Bosch Blow Off Valve - Plumb Back @ Tweakt.net
This is very similar, but pricey
Are you sure its leaking?
All factory BOV's hiss and sound like they are leaking when you are at partial throttle and making boost... this is because there is more air pressure on the top (turbo) side of the throttle than the bottom (engine) side.
