Rear Diff
- caboolture
Rear Diff
Ok here is the plan for a 91 liberty transplant. 92 RS turbo motor with 91 dual range gearbox with a 4:11 diff or 3:9 diff. What i would like to know is the difference. It will be used mainly for on road use. Cheers Peter
1991 gx 3" lift 16" gt Forester alloys,215/65/16 outback struts and pedders raised springs, Turbo motor,gearbox,diff,brakes,bonnet etc now transplanted
- discopotato03
- brumbyrunner
When you're caculating gearing you need to look at the gearbox ratios as well as the diff ratio. I've mixed and matched to get the lowest possible gearing from factory ratios but for your application, you might not want that.
Are you happy with your gearing now? Unless it's been changed you will have:
1st 3.545
2nd 2.111
3rd 1.448
4th 1.088
5th 0.871
Diff 3.9:1
Low 1.196:1
1st 3.545
2nd 2.111
3rd 1.448
4th 1.088
5th 0.871
Diff 3.9:1
Low 1.196:1
Settlement Creek Racing
It would be 3.9 if its gen1 D/R box. if it was automatic it would be 4.11
