cooked engine
cooked engine
hey,
I blew a heater hose and kept driving for bout 3 km's. my car stopped. it won't start at all now, and there's water in one of the cylinders, and wooshy steam came out of the oil filler. When i try and start it, pressure builds up in the radiator and stuff swooshes out when i take the radiator cap off.
My dad says it's stuffed but i don't believe him. What do you reckon?
Thanks from Lisa.
Thanks from Lisa.
You might of blown a headgasket or cracked a cylinder head. You won't know the full extent of the damage untill you have pulled it apart.
What enginr is it?
What enginr is it?
[SIGPIC][/SIGPIC]88 Subaru Brumby (Currently being restored.
84 brumby 2 inch Lift(very rough, Big tires)
Landrover series two. 186 holden banger under hood.
- Battlewagon
or worst case is bent crankshaft/piston due water in the cylinders...
Awesome! lucky you... yeah thats great so you're gonna part out the donor car?fujisoobs wrote:Thanks guys,
picked up an L series thats done 100000 km's less than the touring wagon and running sweet. Dad's doing engine swap so the touring wagon will be back to better than original glory!
Does it idle properly at other times? Does it get smoother the longer you sit at the light?
