Growly RX T rear wheel bearing issue .
discopotato03
Post by discopotato03 » Thu Apr 17, 2008 9:43 am
Hi all , have I think a growly rear nearside wheel bearing so have ordered two kits through CBC Bankstown for $52.46 ea retail . I hope these are the right ones which people say are a double tapered roller bearing cartridge .
Its high time the trailing arms are removed to have their urethane bushes fitted and the anti roll bar mounts changed to suit std two bolt brackets/hoops so will do both sides .
Will post the process after its done , cheers A .
discopotato03
Post by discopotato03 » Thu Apr 17, 2008 10:18 am
Will post the part numbers for them when I get them , if anyone has the correct part numbers for whatever brand bearings work that would be handy so I can cross reference them against what I'm getting and confirm they are the right ones .
Cheers A .
twilightprotege
Post by twilightprotege » Thu Apr 17, 2008 10:51 am
from CBC for the RX, the front wheel bearings are SB184KIT (includes inner and outer seals and bearing), which i can sell for $43 each plus post. rear wheel bearings are SB281KIT (again, includes inner and outer seals and bearing). getting price for the rears moment
BrennyV
Post by BrennyV » Thu Apr 17, 2008 10:53 am
make sure they are the sealed type also from cbc. and work them on the price, i got both front sets for 40buks total ;)
Hunter S. Thompson
twilightprotege
Post by twilightprotege » Thu Apr 17, 2008 11:07 am
my cbc guy recons that those are the only ones he has are the unsealed ones (thus the kit includes seals and bearing). the rear kit suits both disc and drum too by the way.
discopotato03
Post by discopotato03 » Thu Apr 17, 2008 12:50 pm
In this application I prefer non sealed bearings . Thanks for the part numbers and I'll check them when I pick them up this afternoon .
Cheers A .
Late edit , confirmed part number SB281 kit .
Cheers and thanks , A .
twilightprotege
Post by twilightprotege » Thu Apr 17, 2008 2:00 pm
just had an email back from cbc - they said the SB282KIT bearing is sealed, but for 2wd leone only
BrennyV
Post by BrennyV » Thu Apr 17, 2008 5:18 pm
whats the diffrence from 2wd to 4wd? hubs are the same
Hunter S. Thompson
Post by El_Freddo » Fri Apr 18, 2008 9:36 am
BrennyV wrote:whats the diffrence from 2wd to 4wd? hubs are the same
If your asking about the rears - the 2wd rears have an axle stub that the bearings spin around.
The 4wd (as you'd know) have the CV shaft coming through the swing arm, the bearings are in the swing arm... make sense or clear as mud?
Front hubs i've heard there are differences, but I really don't think there are any - front hubs are the same spline diametre as the 4wd counterparts, havn't looked any further into this.
BrennyV
Post by BrennyV » Fri Apr 18, 2008 10:49 am
nah i ment front. i neva have noticed any diffrence.
Hunter S. Thompson
discopotato03
Post by discopotato03 » Fri Apr 18, 2008 11:05 am
Ah actually the rear semi trailing arms have a stub axle in them suspended in the twin opposed tapered roller bearing cartridge .
The outer rear drive shaft joints go over this axle's inner end spline and are retained by roll pins - same deal as the fronts at the inner or gearbox end . The rear is the same system at both inner and outer joints on L series and probably MY's .
Cheers A .
discopotato03
Post by discopotato03 » Sat Apr 19, 2008 7:02 pm
Nearside rear wheel bearing changed - and all for zip because it was fine .
The growling from the back was found to be my cheap nasty temporary 13" tyres because I didn't want to spend money on 13's with the 16's in the wings .
It wasn't the diff either because its currently sitting in the boot rather than under it .
We will change the other side tomorrow afternoon weather permitting so that both sides are new . I was contemplating getting the diff opened up though I don't think I'll bother because it doesn't leak and feels ok .
The job itself seems easy enough though my mechanic friend does have all sorts of nifty drifting tools and tubular tools designed for this purpose .
I gather Subaru intend you to separate the inner and outer arm though we managed with it in one piece .
The staked retaining nut put up a bit of a fight but with patience it came undone . The bearings that came out did not have a one piece outer race like the CBC NTN kit , they were NTN brand but the outer races were separate with a spacer in between .
The hydraulic brake line was easy , my friend used a nifty compact Stahl Willie rubber brake line clamp and let it gravity bleed when it was put back together .
The bonnet lock cable decided to lose its ferrule at the catch end and a temporary clamp was fitted to keep it workable .
Next time you think you have a dying rear wheel bearing swap a couple of wheels around and see if the noise goes away - you may just save a bit of time and money ...
Post by steptoe » Sun Apr 20, 2008 10:30 am
Funny you mention the warning. Several mechanics diagnosed a stuffed front diff bearing on my 92 ute before I bought it - was booked in for a rebuild when the right guy found it was a front wheel bearing.
As for 4WD & 2WD front MY hubs - my CBC bearing kit SB182A is for both.
discopotato03
Post by discopotato03 » Sun Apr 20, 2008 8:52 pm
Offside rear bearing now changed , this one was a touch gritty but not really shot . Now all that's left is to refit the rear diff and drive shafts .
Just on this , with the car up on stands is it possible to fit the shafts to the stub axles and then sit the diff on a trolley jack and get the inner joints on its halfshafts ?
If so then a simple lift to hang the thing by its single front and twin rear mounts would be easy enough .
Cheers A .
