Brumby issues
BRUMBI
Brumby issues
Post by BRUMBI » Thu Jan 24, 2008 4:24 pm
my car is playing up on me its a EA81 with dual range 4 speed, it used to labor a lot up hills or even when ya put ya foot down, now it dosent at all it. it just sh#ts itself, makes a weird sound and losses power.
dose anyone have a clue
thanks kai
84 MY Sportswagon
92 Brumby
87 Rx Turbo
Reg Brumbys
Post by Reg Brumbys » Thu Jan 24, 2008 6:25 pm
I had a similar issue with my Brumby when I bought it.
I did three things trying to fix it
1 - Changed the spark plug leads - still did it
2 - Changed the fuel filters - still did it
3 - Took out the vacum advance unit and tested it (it was rooted) so sent it off to get re-conditioned - put it back on and no dramas since (touch wood).
"The Express"
Subaru Brumby 1990
2" B-Y-B LIFT (New)
Power Steering
14" Wheels with Maxxis Bravo MT-753's
Spotties
L-Series Interior Light
Roll Bar (to be added)
BaronVonChickenPants
Post by BaronVonChickenPants » Thu Jan 24, 2008 6:48 pm
I would also check the condition of your distributor points (if it has them) and your timing.
Jordan.
BRUMBI
Post by BRUMBI » Thu Jan 24, 2008 6:53 pm
how do ya do that
also the timing is spot on but when hot and i turn it off it pre-ignites
84 MY Sportswagon
92 Brumby
87 Rx Turbo
Reg Brumbys
Post by Reg Brumbys » Thu Jan 24, 2008 6:57 pm
Take off the dizzy cap, unscrew the VAU and disconnect the bottom hose, take it off - put your finger on the end that went into the dizzy - suck on the other end - if you can't get a vacum then the diapram is perished and needs to be replaced.
"The Express"
Subaru Brumby 1990
2" B-Y-B LIFT (New)
Power Steering
Spotties
BRUMBI
Post by BRUMBI » Thu Jan 24, 2008 7:02 pm
cheers but i really think its in the gearbox as it feels a little bit like sliping but not clutch
84 MY Sportswagon
92 Brumby
87 Rx Turbo
madmat
Post by madmat » Thu Jan 24, 2008 7:06 pm
the way to test the clutch is put the car into top gear and rev the engine to about 2000rpm. then release the clutch fast. if the clutch is in good condition the engine will stall instantly if the engine slowly dies the clutch is on the way out.
it dosn't sound like a clutch problem to me though.
______________________________
my last 4wd that i built and had fun scaring subarus on fire trails:twisted:
full NSW rego. 270liters diesel. 140liters of water. airide suspension on front axle.
self contained for a week with 6 adults. Island cab was cut and narrowed 300mm to fit the chassis.
Great fun off road. Now lives in FIJI as a mobile dentists truck.
BRUMBI
Post by BRUMBI » Thu Jan 24, 2008 7:11 pm
no i dont think its clutch at all
84 MY Sportswagon
92 Brumby
87 Rx Turbo
SUBYDAZZ
Post by SUBYDAZZ » Fri Jan 25, 2008 11:59 am
Well if it's losing power it can either be the clutch slipping or the motor.
SUBYDAZZ
subybrumby
Post by subybrumby » Fri Jan 25, 2008 5:03 pm
Don't forget that there are two fuel filters..
BRUMBI
Post by BRUMBI » Fri Jan 25, 2008 6:32 pm
na i can feel it throught the gearbox and the hole laboring thing has got me thinking the box is going to shit its self
84 MY Sportswagon
92 Brumby
87 Rx Turbo
Post by Alex » Sat Jan 26, 2008 11:39 am
how can it be the gearbox??
does it miss/cough/splutter at all?
ChPLAT
Post by ChPLAT » Sat Jan 26, 2008 11:55 am
Check to see if you have any short wires. I had one that when ever it shorted the car would struggle but not stall. Maybe going up hill makes it contact?
Past rides-
1989 Brumby
Current ride-
MY06 Liberty 2.5i Sedan
Morcs
Post by Morcs » Tue Jan 29, 2008 4:16 pm
Me thinks you need to get your carby needs sevicing cleaning out including the main jets and Float levels. The poor thing sounds like its running out of fuel.
So many optioins not enough time or money:confused:
BRUMBI
Post by BRUMBI » Wed Jan 30, 2008 4:50 pm
its got a weber on it and has been jetted 2 months ago by carbytune, but i has to be engine now as it was doing it at idle today, almost feels like a spun engine bearing ( could it be that)
my next option is to go for a ej22 or er27 convertion
84 MY Sportswagon
92 Brumby
87 Rx Turbo
Morcs
Post by Morcs » Wed Jan 30, 2008 9:57 pm
Spun bearings normally cause a knocking noise or the motor is tight to turn over. Have you checked valve clearences? In my old Brumby I had the valve clearence close up just enough to make it miss. It would run Fine when Cold but when it warmed up you could hear it coming and going when cruising. Thought that was an ignition miss to start with then tried fuel then checked valve clearences. Not Hard to check. I used to check them everytime i did a service after that. Could do them in a bout 20 mins after a few goes.
BRUMBI
Post by BRUMBI » Thu Jan 31, 2008 5:27 pm
how do ya check them
84 MY Sportswagon
92 Brumby
87 Rx Turbo
Morcs
Post by Morcs » Thu Jan 31, 2008 5:54 pm
You will need to get a set of feeler gauges. Cant remember exact but in the realm of 22thou for intake and 18thou for exhaust(I would be checkin out a manual its been over 12 months since i have done them)(Sold that one 9 months ago and still miss it). You need to remove rockercovers get a set new rocker cover gaskets. Wind motor over untill TDC compresion stroke on Cylinder you are checking clearences, Adjust rocker arms so that you can slide the gauges in and out fairly easly without movement on and off the gauge with rocker arm. Continue for all four cylinders replace rocker covers clean up etc.
Would Recommend getting a manual to do the for the first time. Just loan one from your local libary(They are free!) then you should be right.
SUBYDAZZ
Post by SUBYDAZZ » Thu Jan 31, 2008 8:54 pm
It's extremely unlikely to be a gearbox issue.
SUBYDAZZ
BRUMBI
Post by BRUMBI » Fri Feb 01, 2008 8:02 am
yeah got the manual had an idear of how to do it just good to know how other people do...
cheers might give it a got see what happens
84 MY Sportswagon
92 Brumby
87 Rx Turbo
