Page 1 of 2
Liberty Oxygen Sensor P/N?
Posted: Mon Jan 14, 2008 8:12 am
by SUBYDAZZ
I appear to have a Bosch O2 sensor in my Liberty and I was looking to replace it, some of the numbers on it are rusted over so I can't read it.
I tried to read the catalog on the website but the BC Liberty/Legacy is not listed. There are Subaru Legacy and Impreza Kombis however?
Does anyone know the correct part number off hand?
1992 Liberty EJ22
Posted: Mon Jan 14, 2008 8:13 am
by SUBYDAZZ
Posted: Mon Jan 14, 2008 8:44 am
by Gannon
Any universal o2 sensor will do, just check whether it a 1, 2, 3 or 4 wire one
They have them on ebay for $25
Posted: Mon Jan 14, 2008 10:41 am
by FROG
22690aa150
Posted: Mon Jan 14, 2008 2:53 pm
by SUBYDAZZ
LOL, yeah I was after the Bosch number thanks. I know how much the genuine one is...
Please do remind me!
Posted: Mon Jan 14, 2008 2:59 pm
by FROG
Your Left Arm Lol
JEEZ I JUST LOOKED UP THE PRICE!
Posted: Mon Jan 14, 2008 3:23 pm
by Gannon
Im telling you,... get one of these
NEW UNIVERSAL 2 WIRE OXYGEN SENSOR
It is only $30 delivered and fits all cars.
How many wires does liberty one have?
Posted: Mon Jan 14, 2008 7:07 pm
by AlpineRaven
The Bosch ones that you buy from auto stores ie. Bursons they're around $76 (forgot the part nbr but yes from EJ22 Liberty) - exactly same one as Subaru just different part number... Worth getting i guess.
Posted: Tue Jan 15, 2008 12:04 am
by Matatak
i culdnt find a 3 Wire one on ebay. no point in downgrading to a 2 wire lol
but a 4 wire may be the go from ebay.
wts the price of genuine
i no its gonna be alot but i still wanna no
Posted: Tue Jan 15, 2008 5:07 am
by AlpineRaven
Matatak wrote:i culdnt find a 3 Wire one on ebay. no point in downgrading to a 2 wire lol
Last time about 2 yrs ago from Subaru was roughly $380 for it.
Posted: Tue Jan 15, 2008 9:12 am
by FROG
Yeah 380 About Right
Posted: Wed Jan 16, 2008 2:21 pm
by SUBYDAZZ
It's come down then, last I checked it was $555 (2004).
Posted: Wed Jan 16, 2008 2:23 pm
by SUBYDAZZ
So if these sensors are universal, how come some have 2,3,4 or 5 wires? I assume that they aren't all the same? Don't they just send a voltage to the ECU?
I guess it depends on what voltage for what O2 level?
Posted: Wed Jan 16, 2008 4:33 pm
by Gannon
1 wire = Wire for signal, exhaust pipe/engine for ground
2 wire = One wire for signal, one wire for ground
3 wire = One wire for signal, 2 wires for heating element, exhaust pipe/engine ground
4 wire = One wire for signal, 2 wires for heating element, one wire for ground.
So if the liberty has a 3 wire sensor, buy a 4 wire and simply connect the ground wire to the chassis somewhere. A wired ground creates a better electrical path, rather than through a rusty exhaust pipe.
Posted: Wed Jan 16, 2008 6:38 pm
by Matatak
hehe youre wrong........i think
it has one for earth, one for power from igniton, and one for signal
either that or ive fuked my guage up. i did it to those 3 wires. (earth on guage jsut to the black wire.
andit works.
Posted: Wed Jan 16, 2008 7:33 pm
by Gannon
are you talking about an o2 sensor or a air/fuel gauge?
Yes an air/fuel gauge will have 3 wires- Ignition, Ground and Signal
Mine was Red-Ign, Blk-Gnd and Grey-Signal
As for a 3 wire oxygen sensor, this is from the ebay sellers website
The two white wires are the sensor heater wires. Polarity does not matter. The black wire is the Ecu signal wire.
So one white wire will go to Ignition, the other white wire will go to Ground, and the black wire will connect to the ECU.
Different manufacturers of universal o2 sensors may have different colour codes
Posted: Wed Jan 16, 2008 10:29 pm
by Matatak
now im confused.
im talking bout my Oxy sensor. has 3 wires. one ground (black - goes thru ECU i presume), one Ignition (red), and one Feed/signal (white.
it doesnt have 2 heater wires.
thats wt i meant anyway. and i jsut mentioned i hooked my guage up to it so it must have a ground through the black wire.
were u talking bout the EBAY oxy sensors have 3 wires but only grounds thru the exhaust?
Posted: Wed Jan 16, 2008 11:03 pm
by Gannon
An oxygen sensor doesnt need a power supply to operate, the only reason some oxygen sensors need power is to heat the tip of the sensor so it reaches operating temp (about 300degC) sooner
What engine do you have?
Did you install the o2 sensor?
And by gauge im assuming you mean Air/fuel ratio gauge?
Im assuming that the colours are different, im guessing that the red & black wires supply the heating element, and the white is the signal and goes to the ecu. The ground of the o2 sensor will most likely go through the exhaust/chassis
Did you install your a/f gauge?
Where did you pick up the signal wire and what colour was it?
Posted: Wed Jan 16, 2008 11:08 pm
by Matatak
Suparoo wrote:An oxygen sensor doesnt need a power supply to operate, the only reason some oxygen sensors need power is to heat the tip of the sensor so it reaches operating temp (about 300degC) sooner
Yer i knew that
me gots EJ22
no its stock, but i will be gettin a new one soon and i WILL install it myself. (why wuld i pay for others to do wt i can do
Yes
if that was true then my guage wuldnt work wuld it? i hooked the black onthe guage, which is an Earth, to the Black wire out of the OXY sensor, if that wasnt an earth then my guage wuld have two lots of power going into it and screw up wuldnt it?
Yep
Signal wire off OXY sensor is White, and hooked it up to the white wire on the A/F Guage and it gives me readings.
(it seems me qouting doesnt count to the '10 character minimum' lol)
Matatak
Posted: Thu Jan 17, 2008 8:01 am
by Gannon
Ah ok
No no, that explains why your gauge does work.
The red wire is positive/12v+
The black wire is negative/ground/earth
The heater is wired directly to the ignition, the same as your A/F gauge
The sensor part of the o2 sensor doesnt ground/earth through the black wire, it grounds through the exhaust pipe, the black wire is connected to the same ground/earth somewhere in the wiring loom.
So if you do buy a new o2 sensor from ebay....
The old red will connect to one of the whites of the new sensor
The old black will connect to one of the whites of the new sensor
And the old white will connect to the black of the new sensor
Its a little confusing i know, but i think ive explained it right
