Car faltering
Posted: Fri Dec 28, 2007 6:15 pm
Hi All,
On the way to the coast around 150km away a problem started showing. When just cruising along at around 110kmh the car would occasionally falter just for a brief moment, like it was losing power completely but then correcting and continuing on. It was a 30 degree day.
On the way back (38 degrees and windy) the problem became more frequent and more severe to the point where I had to pull off the highway.
Oil levels and pressure, and water levels and temperature normal for a hot day. I think when I was forced to pull over I saw a bit of smoke puff out the back, but it could have been a bit of dust as it was pretty windy.
No abnormal smells or noises.
Checked battery while engine on ~13.5V, engine off ~12.5 and cranked normal.
There was no way to predict the problem, but in retrospect it seemed to happen more when car was in positive manifold pressure (ie boost). I rarely find the need to use full throttle in the country, and with this problem was not keen to try.
I am thinking there is a problem with the turbo or possibly fuel delivery/ECU.
Any thoughts?
Could this be at all related to the vacuum problem I am experiencing?, in this thread: showthread.php?t=8360
Any thoughts?
