Ea82 won't rev passed 3500-4000
Posted: Mon Dec 10, 2007 7:39 am
Howdy
My 86 leone ea82 carby model which my son is using at the moment runs and revs smooth untill you hit 3500 - 4000 then it just like it hits a wall the engine is running smooth and holds it speed but it stops pulling.
I have taken of the air cleaner off and checked if any of the vacuum hoses may have come off or broken but can't see any.
It is like it is starving for fuel when it gets to these revs, I have just had a look down the throat of the carby With my son pushing the throttle to the floor the primary valve is opened fully the secondary valve is only opened about 1/2 to 1 mm, So i am thinking that is not enough and needs adjustment? if this is so how much should it open eg fully or close it ??
Ok I have now checked the vacuum secondary and with the primary open and sucking on the vacuum can the secondary opens fine.
I am thinking maybe a new fuel filter may help or could it be that the fuel pump is losing pressure
thanks
Marc
38052038 or 0410920488
thanks
Marc
