Water + Oil, eewww. EA81.
tim_81coupe
Post by tim_81coupe » Sat Dec 17, 2005 8:29 pm
My little runabout decided to start stalling at lights today, so I took it home and let it cool down to work on it. I've just popped the aircleaner off and it's full of delicious cream. Oil and water mixed, not good.
I pulled off the hose between the air cleaner and RH rocker cover, it now appears the rocker cover is full of water. The car has been using a bit of coolant, but I figured this to be because of the stock overflow pipe.
I'm about to go out there and pop the rocker covers off, see if I can drain this water out, but can anyone give me an idea of where the water & oil are mixing? Is it a common EA81 fault?
Oh, and EA82's are still worse. This motor still drives. :D
82 MY Wagon, EJ20G
87 RX, EJ20G
89 Brumby, EA81
12 BRZ, FA20
tim_81coupe
Post by tim_81coupe » Sat Dec 17, 2005 8:53 pm
Scratch that, pulling it further apart has revealed a rather poor diagnosis: this engine is cactus.
Still drives though... :P
82 MY Wagon, EJ20G
87 RX, EJ20G
89 Brumby, EA81
12 BRZ, FA20
BaronVonChickenPants
Post by BaronVonChickenPants » Sat Dec 17, 2005 9:41 pm
Sounds like time for another EJ conversion or you could go backwards, be different, do an EK42 conversion, it'd go like a slug but the fuel economy would be unreal :lol:
I'll even donate an EK42 and 4 speed box to the cause :P
Jordan.
Oversteer
Post by Oversteer » Sat Dec 17, 2005 10:02 pm
....like they say ! anytime is TURBO TIME !!! Fuck yeah !
...give me about 6 weeks asnd i`ll have a 90 EJ20G for sale.......choice of gearbox 99GTB or MY05GT.... !!
Look ...don`t act like you don`t want ~150+Kw atw aight !
OS
MY05 GT-STI DCCD 6spd 13.88at98.7
88 FJ62 Cruiser-5.0ChevTPI TT,6psi,Hi6,044,Wolf3dV4,FMIC
Post by BaronVonChickenPants » Sat Dec 17, 2005 10:06 pm
C'mon 27kw of 2 cylinder goodness has to be more appealing than that, how can it even compare :lol:
How can you honestly say no to a 30 minute quarter mile 8)
Jordan.
tim_81coupe
Post by tim_81coupe » Sat Dec 17, 2005 11:24 pm
LOL Justin. I'd consider it if I had the money. Problem is, at the moment I have no money at all. Plus this car is meant to stop me from spending money.
You have made me think about it though....
Oh - and Jordan, I doubt it'd be more economical because I'd end up bolting some stupid amount of boost to it to get it to move, and I'd end up with conrods flying every which way. :) Thanks for the offer though.
82 MY Wagon, EJ20G
87 RX, EJ20G
89 Brumby, EA81
12 BRZ, FA20
BlackMale
Post by BlackMale » Mon Dec 19, 2005 12:00 pm
Sorry to hear Tim. She can sit on blocks next to mine... u no keep her company :( lol
subgiraffe
Post by subgiraffe » Mon Dec 19, 2005 12:44 pm
Check the manifold gasket. I've had water in RHS rocker cover three times on EA81's each time due to RHS manifold gasket.
The bolts holding the manifold on seem to shake loose and then you get water in the manifold when the engine gets warm
subanator
Post by subanator » Wed Dec 21, 2005 11:49 pm
subgiraffe wrote:Check the manifold gasket. I've had water in RHS rocker cover three times on EA81's each time due to RHS manifold gasket.
If is wasnt for reading this topic, I might have had a similar prob myself. Looked under the bonnet yesterday and sure enough, oil had started to make its way up and out of the rear RHS manifold bolt. Had to retighten that side a fair bit. Thanks for the tip Subgiraffe!
smoov
Post by smoov » Thu Dec 22, 2005 5:46 am
hey tim,
would this be out of the question?
http://cgi.ebay.com.au/Subaru-Engine-EA ... dZViewItem
1998 Subaru Legacy GTB
tim_81coupe
Post by tim_81coupe » Thu Dec 22, 2005 9:31 am
Yeah it's a little to far for me to pick up, smoov, but nicely spotted.
I'm going to have the reco done on this motor, remember I have 4 other EA81's around the place so if something's iffy on this motor I should be OK.
I'm calling in a favour from an old customer of mine, should see the car back on the road with the engine reco'd and new CV's for a tad over a grand.
I'm going to have it done mid-January, should be interesting as thats exactly when I'm changing jobs....
82 MY Wagon, EJ20G
87 RX, EJ20G
89 Brumby, EA81
12 BRZ, FA20
KERRY
Post by KERRY » Thu Dec 22, 2005 2:50 pm
Chemiweld might buy you a little time , just empty radiator and fill with water, warm up, enter chemiweld , idle some more and take for a drive, it worked on my MY and I had no more whip cream.
tim_81coupe
Post by tim_81coupe » Thu Dec 22, 2005 7:48 pm
Chemiweld will make it near impossible to remove the cylinder heads. Seeing as I want to reco this motor I think I'll stay away from the stuff.
82 MY Wagon, EJ20G
87 RX, EJ20G
89 Brumby, EA81
12 BRZ, FA20
mattims
Post by mattims » Thu Jan 12, 2006 3:16 pm
hmmm chemiweld .... my ea82 is going again thanks to that stuff.. although it still seems to be using coolant... as far as i can tell its not leaking anywhere though. Any ideas as to where it could be using it? (car is running really well since i changed timing belts so i have my suspicions they may not have been on right before)
BlackMale
Post by BlackMale » Thu Jan 12, 2006 5:15 pm
mattims wrote:hmmm chemiweld .... my ea82 is going again thanks to that stuff.. although it still seems to be using coolant... as far as i can tell its not leaking anywhere though. Any ideas as to where it could be using it?
Are both caps secure? I am assuming that you are not smelling coolant, correct?
mattims
Post by mattims » Thu Jan 12, 2006 5:21 pm
yeah both caps are secure. Heater core isnt leaking. have inspected engine running (hot and cold) cant find any leaks. But given about 100k's of driving and then cooling down and the overflow bottle will be empty and the radiator will be lowish (where you can just see the top row sticking up above the coolant).
