Brat lost power. Possible reasons?
russty
Post by russty » Sat Aug 25, 2007 2:39 pm
Hey so i got a brat that slowly lost power i checked every thing spark, fuel i rebuilt the carb, but then i thought i did it wrong so i just bought a new one $500 of racing power. But still the same im thinking its the vacume advance on the distributer but cant check it at the moment. What do you all think?
BaronVonChickenPants
Post by BaronVonChickenPants » Sat Aug 25, 2007 6:00 pm
Have you checked the distributor points, unless it's electronic of course.
The vacuum advance mechanism can seize, just spray inside the dizzy with some WD40 or INOX and work it free with a screw driver or pliers from inside the distrubtor.
If it does have points make sure you keep them dry.
I hope that dribble makes sense.
Jordan.
Post by steptoe » Sun Aug 26, 2007 10:35 am
compression, compression, compression does it rev freely no load ?
russty
Post by russty » Sun Aug 26, 2007 11:44 am
it will sit there just fine but when you get it on the road it doesn't want to go anywhere.
Matatak
Post by Matatak » Sun Aug 26, 2007 11:57 am
possibly timing then
or like BVCP said about the dizzy
i dunno might think of sumthin else later
Wagon is no longer....:(
The Subaru Wacky Workshop
-All About the WA Boys :D
drover22
Post by drover22 » Sun Aug 26, 2007 6:40 pm
Mine did a similar thing once and couldn't find exactly what it was but got the S---ts and did the plugs and everything but also pulled all the mongrel vaccuum lines off and joined them back up with a bit of silastic to each join no more problems. Just do them one at a time so you don't get stuffed up.;)
Post by BaronVonChickenPants » Sun Aug 26, 2007 7:05 pm
Now that you mention that I do remember having a T piece in one of my vacuum lines break, which caused the engine to run lean and lose power, it also pinged heaps.
Lightly spray some WD40 around (not on) your vacuum lines with the engine idling, if the revs change then you've found a vacuum leak.
Jordan.
SuBaRiNo
Post by SuBaRiNo » Sun Aug 26, 2007 7:59 pm
Fuel filter... or pump.
Dave
Post by steptoe » Tue Aug 28, 2007 8:16 pm
do you know what a slipping clutch feels/sounds/smells like ?
rip h'brake on and drop clutch in gear, stall or just keep on revving there, in gear?
russty
Post by russty » Sat Sep 01, 2007 7:54 am
Sorry i've been gone but WOW i'll be sure to try out all that out and see if anything works. I'll let you guys know as soon as possible if it works out or not. Thanks alot.
