Rx 1.8 turbo need help over heating
so this babys over heating really bad it will sit there just fine but when you get it on the road its gutless and the turbo heats up like crazy. i need some help i've been told it might be the timing. so far i've erased the comp memory cleaned the injectors everything should be running fine. im about to go get the comp checked.
well no luck on getting the comp tested yet. They only check trouble codes and anyone can do that. But anyway its a Turbocharged 1.8 litre engine and full-time 4WD with over head cams so you know for sure. 1988 this thing is an awesome collectable but its pissing me off. I still think i might have messed up the timing any suggestions on how to time this thing right?
- Chris_Rogers
- Chris_Rogers
Intercooler should be the first mod you do, then you can up the boost a bit
RS liberty water/air intercooler is good, or if you want to put a hood scoop in, use a WRX top mount
You sure could, the plumbing is the same, you will just have to make a scoop for your bonnet to feed cold air into it.
http://cgi.ebay.com.au/SAAS-AIR-FLOW-BO ... dZViewItem
I'm using this one, it fits perfectly on the L sereis bonnet and is cheap! plastic though & i chucked the crappy looking mesh
timmo
timmo
L series wagon EA82T (RIP)
'92 Liberty RS Turbo
GU Patrol Ute
Honda XR400R
GU Patrol Ute
Honda XR400R
2.5 wuld be better than 3 i think 3 is way to big and ull loose back pressure dont count on my input but
maybe 2.5 is still to big to get the peak power outta it aswell
maybe 2.25 shuld be considered
neway see wt otha ppl say as i aint sure with these ones
Wagon is no longer....
