tyre size help
Posted: Fri Jul 13, 2007 11:00 am
by FROG
ive got a set of 16" imprezza rims and need new tyres can i go with 60 series with no rubbing? i run a stock 92 lib constant awd dual range...cheers gtf
Posted: Sat Jul 14, 2007 1:55 pm
by cooloothin
not sure if it'll help you in your situation, but you could measure up your current wheels and check the gaps you have, then run your new ones and current ones through this
Posted: Sat Jul 14, 2007 2:55 pm
by AlpineRaven
205/55/16" Is what I had on my Liberty 1995 model.
Posted: Sat Jul 14, 2007 6:16 pm
by daza
Posted: Mon Jul 16, 2007 9:14 am
by FROG
cheers guys i went with 215 60 yes big arse 60 x 16 got a bit of rubbing on rear spring perch and they snagged the guards a bit landing a little jump so got some spacers organized and i spose ill have to roll the guards....
Image[/IMG]
Posted: Tue Jul 17, 2007 10:24 pm
by Alex
cooloothin wrote:not sure if it'll help you in your situation, but you could measure up your current wheels and check the gaps you have, then run your new ones and current ones through this
that link is severely cool!
