carbon cannister probs. ej22
Posted: Sun Apr 08, 2007 1:09 pm
by Alex
Hi all,
we have just finished my conversion, and i have one semi large problem. The corbon cannister is filling with fuel after abit of driving. It then leaks out the breather hole in the bottom. It has to a fuel line connected wrong or sumthing...anyone got any ideas?
cheers
Posted: Sun Apr 08, 2007 2:51 pm
by SuBaRiNo
Makes me wonder where the fuel is coming from... you do have a fault code relating to your purge control solonoid which is connected to the carbon canister.
For now... i would disconect the carbon canister and block all the lines... This will work for now... only problem resulting from this may be some built up pressure in the tank but during these cooler days it would be fine.
I would have to research more on how the fuel return system works on the carb L series... i was under the impression that anything coming out of the evap lines of your tank and into the canister had to go via a fuel/vapour separator that would have to fill up completely with fuel before it would put fuel into the canister.
Dave
Posted: Sun Apr 08, 2007 2:54 pm
by SuBaRiNo
This does sound like a similar problem to Aspro... his carbon canister was removed and plugged but over time the built up pressure did split his fuel tank.
Dave
Posted: Sun Apr 08, 2007 6:18 pm
by Alex
what about just joining the two hoses which come out the cannister? i have done this, and have been driving it abit with no problems..
Posted: Sun Apr 08, 2007 10:12 pm
by BrennyV
is this only related when running a mpfi tank?
Posted: Sun Apr 08, 2007 10:15 pm
by SuBaRiNo
This i think would be a carby tank problem i would assume... i think caused by the location and diameter of the fuel return lines.
Dave
Posted: Sun Apr 08, 2007 10:17 pm
by BrennyV
and also the fact that the mpfi tanks are baffeld also??
by SuBaRiNo
that has more to do with the fuel pickup than the return.
Dave
Posted: Sun Apr 08, 2007 10:26 pm
by BrennyV
ahhhz okies
Posted: Mon Apr 09, 2007 7:35 am
by fredsub
The Lseries has 3 lines going to the fuel tank, the larger return line is the vapour line, that is the one that should go to the cannistor. (3 connectors on the cannistor, now EJs only have 2 on the cannistor, so the hose must go somewhere else on the vapour circuit)
Easy to get the return fuel/vapour mixed, the result is that fuel coming from the bottom of the cannistor, and happens when you turn engine off or hot conditions forcing fuel from tank, or a pressure build up in the tank, because fuel up the vapour line is blocking , where it normally goes the the cannistor to relieve pressure - with which its a closed circuit.
Also note the vapour line enters high up on the fuel tank filler.
I would not suggest the stupid idea of drilling a hole in the fuel cap - just fix it properly now that you should understand it a bit more....i hope?
Posted: Mon Apr 09, 2007 1:43 pm
by SuBaRiNo
Looks like thats what they have done... got the vapour and the return mixed up.
Dave
Posted: Mon Apr 09, 2007 1:45 pm
by D3V1L
definetly not......we studied the strip down manyal very very hard on saturday night.....
Posted: Mon Apr 09, 2007 2:21 pm
by BrennyV
this might be something i might look into also
Posted: Mon Apr 09, 2007 2:23 pm
by Alex
well i have them all blocked off now...no probs at all..
still managed to keep up with a newer v6 magna..(and i had three people in my car compared to his one!)
Posted: Mon Apr 09, 2007 2:25 pm
by BrennyV
i had no fuel on my short run lastnight.. when did you 1st notice urs alex?
Posted: Mon Apr 09, 2007 2:28 pm
by Alex
after about 100km of driving...well from andrews to mine, back to andrews, and then after andrew went on that food run..
