EA82 distributor vacuum line
mroberts
Post by mroberts » Sun Mar 25, 2007 4:02 pm
Is this a "normal" vaccum line ?
I was trying to use it to read manifold with a GM MAP sensor and the results are a little odd.
With the ignition on and the car off (so power to sensor and engine not running) it reads 5 V, which matches for atmosphere.
With the car idling, it STILL reads 5 V, or just a shade lower - atmospheric pressure at the distributor.
When I rev the engine (which should bring the manifold pressure UP from vaccum), the voltage goes DOWN, finally indicating vaccum.
This is making NO sense.
fredsub
Post by fredsub » Sun Mar 25, 2007 6:19 pm
thats correct for the advance vacuum i think, as rpm increases so does the advance........
I think for what you want to do is tap into the manifold...might need to drill a port, actually there should be one there, only not fully drilled through,
Oversteer
Post by Oversteer » Sun Mar 25, 2007 6:29 pm
The dizzy will see whats called "ported vaccum" i.e it doesn`t see vaccum when the throttle is closed/@ idle...only after the throttle is cracked a certain amount/on cruise.
Not having vaccum advance @ idle increases idle stability and torque for take off....you only want advance from the dizzy vaccum module to aid fuel economy on light load.
Drill a hole in the manifold...or maybe there is another line there you can use/T off.
OS
MY05 GT-STI DCCD 6spd 13.88at98.7
88 FJ62 Cruiser-5.0ChevTPI TT,6psi,Hi6,044,Wolf3dV4,FMIC
mroberts
Post by mroberts » Sun Mar 25, 2007 8:59 pm
Ahh, OK. Didn't realise there was some smarts in the vacuum going to the distributor.
It's a carby EA 82 in an '88.
I'll have a look - I think there's a manifold vacuum line, but it's just further from the sensor.
