Stalling at Idle
Posted: Tue Feb 06, 2007 9:21 pm
After installing a 32/36 Weber (EA81) recently i have had trouble with it stalling at idle and running rough randomly; choking it doesn't seem to affect it, maybe makes it worse (when the above is happening). I have blown out the fuel lines and check fuel pump and seems to be working correctly. And will replace the filters tomorrow. It sounds like maybe Float level? If so whats the easiest/best way to do it (on a weber)? What are everyones else thoughts?
Thanks
Matt
Thanks
Matt
