cv joints
Posted: Fri Dec 05, 2025 1:31 pm
I have recently replaced five right hand side inner cv boots and destroyed two joints in the process. I subsequently found that the Kings springs I installed raised the ride height 30 mm and I also installed a 50mm Subarino body lift Kit. Subarino advise that the lift will not alter the CV angle.
I have put the original springs back in. The catalytic converter is directly below the inner cv and am wondering if heat is also contributing to my problem. I plan to wrap the cat'' with Car Builders Direct To Heat Muffler Shield. The Brumby let me down three times crossing the Nullarbor and I am now a bit gun shy of taking it on any long runs. I have also put a Weber 32/36 on her supplied by Recarb in QLD and am using 12 Litres per 100kms which seems to be excessive. Any advice on my problems would be appreciated.
Brendan
Brendan
