I placed an air-air TMIC and BOV on an EA82T. Obviously the unit was installed correctly (well I have no reason to believe that it wasn’t) and there was no dyno testing nor any adjusting of anything else – Eg Advancing the timing. – so if there is anything that I should have done in conjunction with this I am willing to hear them.
Now I was going to go with a “through seat of the pants” for the performance increase however, unfortunately this unit installation has coincided with some warmer weather making it difficult to ascertain any significant performance increase/gain if any – bugger it!
Anyway what we have noticed already is that ;
1) the seems to turbo spools up a little quicker with the TMIC.
2) the reduction on turbo lag.
3) the BOV makes some real noise (which I also would have expected with an atom BOV).
4) the turbo has a high pitch whistle which is a little more noticeable (no other modification have been made to air induction).
5) a possible lag of performance in 5th gear – without changing gears and putting my foot down the turbo spools up however I do not think that its converting it into the power I would have expected.
6) May or may not be related… shortly after installation sometimes in 1st gear (and sometimes in 2nd gear) there is some kinda grinding noise which I can not place - (edit i now think that it is related as after 2 days the grinding noise is not there anymore).
Things I have already though about doing and/or changing.
6) Before I see the feedback to this I will attempt to make sure that the system itself is not leaking... hmm may fill it with water and see what happens.
7) I will change 1 of the rubber hoses as 1 of them is a little softer then I would have liked.
Note At this stage I have removed the TMIC and replaced the original plenum as I was unsure about the system leaking.
Now that you have endured all my ramblings any other ideas and/or suggestions.
Thanks.
