Indicators Not Working.
Sounds like our rig is falling apart doesn't it.
It would appear that the indicators and hazard have stoped working.
I have had a look at the fuses and they all seem to be ok, I even swap a few of them and nothing, the dash clock and other lights etc are also working fine so my initial guess is that something in the stalk had gone KaPut.
Sorry about the lack of info but that's about it.
Any ideas?
Any ideas?
I dont know if this applies to more modern cars, but i lost indicators on my 1969 renault once upon a time. Turned out to be the little "flasher" unit for the indicators- just a small plastic box with a few relays in it. A universal replacesment was like $5 from Repco.
Don't know if this is the problem in your case though...
Julian
2004 Outback H6
2004 Forester XS
Organ donation saves lives
2004 Outback H6
2004 Forester XS
Yeah does sound liek the fasher unit if u have lost the hazards also... unlikely to have a fault in both the hazard and indicator switch.
Dave
Dave
- tim_81coupe
I have only ever blown one... worked on minute fine... totally dead the next.
Dave
Dave
- Suby Wan Kenobi
true true.
Dave
Dave
taking that into account im sure if the hazard light switch went faulty then this would also cause the problem described.... U have a spare L series Jaffa... start swapping stuff.
Dave
Dave
Could also be a bad earth.
Remember that in Leones the flasher relay is integrated with the indicator stalk behind the steering wheel and is not one of those cheap plug in relays. You'll need to take the steering wheel off to replace it.
The indicators only flash when i dis/arm the alarm.
Thanks for the feedback i will attempt to look at it this weekend.
if it flashes with the alarm then the fault is before the wires leave the flashing unit... backing up our idea of it being flasher unit or switch.
Dave
Dave
