Sudden increase in fuel consumption
GTlegs
Post by GTlegs » Mon Nov 27, 2006 2:18 pm
My has recently began to consume more fuel. And it seems not to come from driving, but from being parked for a while.
So i park my car, then come back to it in two to three days, and the fuel gauge shows much less petrol than before.
Car is parked at home. There is no smell of petrol so i dont think its a leak. Any ideas?
Suba
Post by Suba » Mon Nov 27, 2006 5:05 pm
It may be the fuel gauge that is faulty . are you getting roughly the same k's from a tank when you fill up.
Mike.
GTlegs
Post by GTlegs » Tue Nov 28, 2006 8:24 am
No, its gone down from about 550 to 400-450.
subgiraffe
Post by subgiraffe » Tue Nov 28, 2006 6:40 pm
I had a leak in my wagon at one stage that was just like that. there were a couple of pin holes just above the seam of the fuel tank - it was evaporating long before leaving a trail.
gx_rex
Post by gx_rex » Tue Nov 28, 2006 6:57 pm
may have a neighbour siphoning your tank... :)
Suby Wan Kenobi
Post by Suby Wan Kenobi » Wed Nov 29, 2006 10:53 pm
IF you are using more and the car is not using it it must be getting relocated to another place my a 3rd party
The long road ahead
SuBaRiNo
Post by SuBaRiNo » Wed Nov 29, 2006 11:29 pm
Could try blocking the evap line comming from the tank and see if pressure builds in the tank after leaving it for a day. No pressure surely would mean a leak in the system some place.... possibly fuel cap not sealing.. etc etc.
Dave
BRUMBY
Post by BRUMBY » Sat Dec 02, 2006 9:02 pm
Try o2 senser or air flow meter two common problems. especially if it degraded quickly.Also try changing plugs and if it has a cat convertor check if it is blocked
Willie
Post by Willie » Thu Dec 07, 2006 9:20 pm
I had this same problem with a Kombi a number of years back. Ended up being a pretty easy fix..........
I fitted a lockable fuel cap!
Willie.
Canberra
MY06 Forester XT Luxury
MY05 Pajero Exceed DiD
1975 VW L Bug (1303)
