crank pulley bolt
crank pulley bolt
Post by Alex » Sat Nov 25, 2006 5:49 pm
hi all,
just wondering how people get their crank pulley bolts on supertight? mine has come of twice now..both times while doing nuts in the sand...
ea82..
cheers
fredsub
Post by fredsub » Sat Nov 25, 2006 8:19 pm
big big extender bar to your socket, and put it in gear
Post by Alex » Sat Nov 25, 2006 8:24 pm
yeh thats what ive done...once the bolt gets pretty tight the whole lot moves though.....
mattims
Post by mattims » Sat Nov 25, 2006 8:47 pm
loctite works ok .. but then its f**king hard to get off again.
but put it in 3rd or 4th gear and park brake on full or get someone to stand on the brake and you should be able to get it pretty tight
Post by Alex » Sat Nov 25, 2006 9:25 pm
thanks matt...i loctite'd it...and did it up with 120% of my muscle..hopefully it wont come out in a hurry!
Suby Wan Kenobi
Post by Suby Wan Kenobi » Sat Nov 25, 2006 9:37 pm
You did check to see that the keyway was in good condition, when they where the pulley is allowed to move and then the bolt becomes loose and further wears the keyway.
The long road ahead
tim_81coupe
Post by tim_81coupe » Sat Nov 25, 2006 11:59 pm
The way I do it is to put it in a forward gear without the handbrake, and simultaneously tighten the bolt and attemp to push the car back.
82 MY Wagon, EJ20G
87 RX, EJ20G
89 Brumby, EA81
12 BRZ, FA20
