lseries crossmembers...
- waggaclint
does anyone no if all Lseries crossmembers are same (except turbo ones)..
i ask this because im about to put p/steering on mine and ive noticed that the p/s rack in alot thicker in diameter than the original manual steer one...
and were it bolts up to the crossmember looks alot smaller and i dont think it will bolt straight in.....what do ya all reckon has anyone done this or seen it before....my car is a 91model and the p/steering came of a 87model i think....
2011 Forester X
- Suby Wan Kenobi
- waggaclint
- waggaclint
- Suby Wan Kenobi
- Captain Obvious
the plate subi one is talking about is in the middle of the x-member and dipps down a little it will have holes in it to bolt it back up but should be just spoted there or may even be bolted allready dont through it out put it back as is does strenthan things a little
- waggaclint
oh that plate it already has bolts in it....im talking about were the rack accually bolts up hey..there is a cut out in the xmember (like a half moon)that the sits in and then bolted up..but the p/steer rack i have is twice the diameter of the manual rack so it would just bolt in like the manual one it will accually sit lower and not in the cut out(with the half moon)....
2011 Forester X
