differences in water pumps
wrx_nut
Post by wrx_nut » Mon Nov 20, 2006 9:28 pm
is there any differences in a NA ea82 and a ea82t?
cheers
i no theres about a $30 difference in them
fredsub
Post by fredsub » Tue Nov 21, 2006 7:24 am
apparently Not with subaru part nos,
aftermarket, apparently there is a distinction....don't know what? go the subaru one, its cheaper anyways.
search the forum, i wrote the partno somewhere...
Post by steptoe » Tue Nov 21, 2006 9:19 am
105mm or 110mm deck heights so said in here somewhere. I stuffed around with suppliers for weeks and they got me the EA82T listed pump and still appears to be wrong !! The deck height appears to be just the difference in how far along shaft the fan flange sits > I resolved I will be able to press flange in correct direction to make fit. I think differing flange locations depend on NA, T or T with ribbed fan belts !
Part number for Enduro brand supplied out of Melbourne for EA82T W3034E $98 retail
wrx_nut
Post by wrx_nut » Wed Nov 22, 2006 11:00 am
just put a carby ea82 water pump on my ea82t and it fits perfectly...shafts are the same.. put them both next to eachother and couldnt notice any differences at all..
$60 around that price compared to $120 for an ea82t one....
do they have different flow rates?
wrx_nut
Chris_Rogers
Post by Chris_Rogers » Wed Nov 22, 2006 6:56 pm
yes there is a difference in height. I had this probelm with my old sedan when I bought a pump for it. about 5mm difference - NA is shorter.
Audio Express
1987 HR31 Nissan skyline
1990 R32 Nissan Skyline GTS4
wrx_nut
Post by wrx_nut » Thu Nov 23, 2006 3:48 pm
well mine is on the car and seems to line up ok and runs good..?
vincentvega
Post by vincentvega » Thu Nov 23, 2006 4:56 pm
you need to use a puller to adjust the pulley on the shaft to line up with the other pulleys. Had the same problem recently in a mates EA82T. We thought it must be the wrong pump, turns out theyre all like that..
Post by steptoe » Fri Nov 24, 2006 11:21 am
and the suppliers charge extra coz the flange is in a different line up !!
wrx_nut
Post by wrx_nut » Fri Nov 24, 2006 2:54 pm
well i bought the na ea82 water pump and fitted it to my ea82t motor and it all seems fine.. does that sound strange>?
seems to be working fine...
vincentvega
Post by vincentvega » Fri Nov 24, 2006 6:52 pm
if it lines up then you got lucky. if it doesnt you adjust it.
as long as in the end it all lines up your all good
wrx_nut
Post by wrx_nut » Fri Nov 24, 2006 9:07 pm
now worries thanks for that guys...looks like im lucky :)
