Injectors - Spot the difference!
tim_81coupe
Post by tim_81coupe » Mon Aug 21, 2006 8:07 pm
Injector on the left is a 550cc high flowed jobbie, purchased ages ago with the intention of going into my coupe. Injector on the right is a stock EJ20G 380cc unit.
I had previously sat the injector in the rail and it seemed OK, however I'd not tried to fit them because I knew the rest of the fuel system wouldn't keep up. I've just gone to fit them and the little caps wouldn't push down over them, and at this point I put them side by side. Quite a few differences.
Can anyone tell me how I can fit these in? Perhaps by fitting later model / aftermarket fuel rails? More to the point, can someone tell me what they'd be from? The guy said something about being the full 550cc from a JDM STi, but I thought the yellow tops were 440cc?
82 MY Wagon, EJ20G
87 RX, EJ20G
89 Brumby, EA81
12 BRZ, FA20
Chris_Rogers
Post by Chris_Rogers » Mon Aug 21, 2006 8:56 pm
mine are black on the TT I have. not sure if that helps.
Audio Express
1987 HR31 Nissan skyline
1990 R32 Nissan Skyline GTS4
Oversteer
Post by Oversteer » Mon Aug 21, 2006 9:44 pm
You have a MY99 side feed...most likely a std 440 MY99 yellow....
I just sold a set of 720CC my99 injectors..
You need <99 injectors...unless you want to go bosch top feed with custom rails or somthing...
There are a few options you have...non that easy or cheap but there are options.... unless v3sti ones(440) will do you !...just sold 2 sets !
OS
MY05 GT-STI DCCD 6spd 13.88at98.7
88 FJ62 Cruiser-5.0ChevTPI TT,6psi,Hi6,044,Wolf3dV4,FMIC
waggaclint
Post by waggaclint » Mon Aug 21, 2006 11:43 pm
i dont no what there out off but id make up a new rails to make em fit..my work makes em all the time for all sorts on vehicles..
2011 Forester X
tim_81coupe
Post by tim_81coupe » Tue Aug 22, 2006 12:20 am
Hmmm... so these are MY99 ones, makes sense now.
440's will certainly do, you don't have a spare set do you OS? Haven't seen you in a while either, gotta catch up!
82 MY Wagon, EJ20G
87 RX, EJ20G
89 Brumby, EA81
12 BRZ, FA20
Oversteer
Post by Oversteer » Tue Aug 22, 2006 10:55 am
I may know some one with a set...I`ll ask !
If you had of been after V3sti440 about a month ago there was a flood.....3-4 sets for sale, but they have all gone to good homes !
OS
