ECS Warning light
Posted: Mon Aug 14, 2006 11:39 am
by timmo
Does anyone know what the ECS Warning light on the dashboard of an EA82T eqipped L series sedan refers to? (Its one of the red warning lights on the right hand side of the steering column). I'm sure its not major - just a faulty sensor or something?
Posted: Mon Aug 14, 2006 12:07 pm
by Fatz
i believe it means "check engine"
Check the ecu for error codes, then go from there
Posted: Mon Aug 14, 2006 2:08 pm
by timmo
and you do that how....?
Posted: Mon Aug 14, 2006 2:16 pm
by Fatz
underneath your steering column, turn you keys to ignition(where ya dash lights come on, just b4 u start your car), then poke yuor head down and look thru the gap between steing column and plastic surrounding, ull see a red LED flashing at you.
the series of flashing will tell you where your problem is.
with the flashing, there will be different series of short and long emittions.
to start off you will have a longer emitted led, then after that, a couple of short ones.
for example, long led, short short.. this is 12. or long long short short short, 23.
if there are more than 1 error code, after the short series, there will be a small amount of time where the led is off, then will start again with another code.
if there is only one error code. it will keep on repeating itself..
make sense?
i prolli just confused u more.. hehe
have fun
Posted: Mon Aug 14, 2006 2:19 pm
by bluesteel
have a look down the bottom of the steeting column and you should see a flashing red LED
ill see if i can find a link to what the codes mean
Posted: Mon Aug 14, 2006 2:26 pm
by Fatz
Posted: Mon Aug 14, 2006 4:38 pm
by timmo
Ok I think I understand now - I cant look at the car right now - but it isnt likely to be anything major eh? The engine seems to run ok. Would it be a bit reckless to not address the problem causing the error? just a faulty sensor? the engine is going in my wagon sometime. I guess i should identify the problem first... hmmmm
Posted: Mon Aug 14, 2006 4:46 pm
by Fatz
will prolli be a 02 sensor or something like that?
Posted: Mon Aug 14, 2006 4:53 pm
by timmo
if it were the o2 sensor - would the engine be running like shit?
Posted: Mon Aug 14, 2006 4:58 pm
by Fatz
mm unsure, i havent had any 02 troubles..
might chew thru the fuel a bit more than usual?
occasionally run a bit rough.. check the codes and ull know for sure what the problem is
Posted: Tue Aug 15, 2006 12:25 am
by Suby Wan Kenobi
If its from an RX then no the O2 sensor wont make it run odd but if its running rough it would more likely be the Water temp sensor.If you have been through water or washed the engine bay then it could be water making the sensor read erradically in that case it will throw a fault code at you.
Posted: Tue Aug 15, 2006 12:15 pm
by timmo
Yeah thanks, its turned out to be code of 35 - which means either the air flow meter or the EGR solonoid. could just be a dodgy connection too. The car does run ok though
Posted: Tue Aug 15, 2006 12:25 pm
by Suby Wan Kenobi
Take the plug off and spray some WD or contact cleaner in the plug and silde it on and off a few times that should clear off any oxidization off the terminals and provide a good contact area.
Posted: Sun Sep 10, 2006 3:51 pm
by timmo
I've checked out that ECU codes page that Fatz posted, but I dont know how to identify the connectors on the ECU that should be joined in order to clear the codes. Can anyone help? ie the colour of the plugs or something? I Dont actually know if i've fixed the problem, but would like to know by seeing if the codes will clear
Posted: Sun Sep 10, 2006 4:01 pm
by timmo
Oh yeah its got the 'flapper' type AFM aswell . .. anyone know where I could find a spare one? I've got a spare hotwire one here but no flapper. doh.
Tim
Posted: Mon Sep 11, 2006 9:04 am
by timmo
can anyone tell me which connectors are for clearing the error codes????
