RS twin piston front calipers
Posted: Fri Jul 28, 2006 3:46 pm
by PeeJay
How do you pull the pistons out to clean them? I have a pair that are a bit sticky and rusty(on the outside) and need a good cleanup, but I don't have a clue what I'm doing:)
Some pointers would be doog.
Posted: Fri Jul 28, 2006 8:37 pm
by Chris_Rogers
blow them out. other than that a brake shop can get them loose.
Posted: Fri Jul 28, 2006 10:20 pm
by waggaclint
id probably recommend that you get a mechanic or a brake mob to do it for you if your not to sure what your doing. playing with brakes can be dangerous if ya dont no what ya doing.....
Posted: Sat Jul 29, 2006 9:48 am
by PeeJay
All I want to do is get the pistons out so I can clean the cylinders, I just wasn't sure if there was some special trick I didn't know about.
Posted: Tue Aug 01, 2006 12:55 am
by waggaclint
pull the bleeder nipple out and blow compressed air in there put a small piece of wood in front of the piston so you dont damage it...
Posted: Tue Aug 01, 2006 12:57 am
by seagull
or smack your self in the head .
Posted: Tue Aug 01, 2006 9:46 am
by PeeJay
Hahaha ok thanks
