Injector Cleaning fluid
Posted: Fri Jul 14, 2006 5:14 pm
by wrx_nut
is this stuff you can buy to put in your fuel tank worth it?
does it do much?
also do NA MPFI ea82 injectors fit on the turbo EA82T ??
cheers
wrx_nut
Posted: Sat Jul 15, 2006 12:19 am
by Suby Wan Kenobi
I have used it once before and noticed a difference in fuel consumption (it got better)
Yes the NA injectors will go in the turbo holes but they will flow less
Posted: Sat Jul 15, 2006 10:48 am
The best injector cleaner I have USED is the ProMa stuff. It is sold through a multi level marketing system unfortunately , but it must be good for a Toyota dealership to have their name on it and on their shelves some years back.
This stuff has fixed misses in under 16 km numerous times, cleaned out a volvo in tank filter - going from sputter, sputter to screaming up the highway - to the extent that the guy never went back for his new filter ! He bought a bottle of the stuff instead !! 500ml bottle about 20 bucks but treats 625litres (why do I remember that detail ??)
Mobil used to sell Positive Powerrr, that was good stuff to just soak them in overnight for a ripper clean !!
Posted: Sun Jul 16, 2006 8:26 pm
by wrx_nut
righto might get myself a bottol and see how it goes....
cheers
Posted: Sun Jul 16, 2006 11:22 pm
by subanator
Suby Wan Kenobi wrote:I have used it once before and noticed a difference in fuel consumption (it got better)
TA DA! Suby Wan Kenobi, you may have solved my problem, I couldnt get enought flow with my EA82T, it might be possible that the injectors were swapped at conversion??
How do I tell the difference between N/A to Turbo injectors or is the resistance measurement different? Is the load resistors different.
I would realy like to get to the bottom of this problem.
Cheers Roger.
Posted: Thu Jul 20, 2006 6:22 pm
by yarney
I used a bottle of that stuff in my ea82t cost me $30 but worked really will used to run rough as, idle was all over the place now runs smooth worth the money.
Jan
Posted: Thu Jul 20, 2006 8:46 pm
by Willie
I've used a few of the ProMa products and have had good results with them all. Cannot find a distributor up here in Darwin, though.
Anyone on the site sell this stuff? Or know where I can get in contact with a seller?
Cheers.
Posted: Thu Jul 20, 2006 10:50 pm
there may be a market for you up there, maybe sign up yourself ? the parent mlm company used to be Grace Cosmetics and those distributors sold ther pro ma stuff too. google pro ma .com.au ?
Posted: Fri Jul 21, 2006 4:26 pm
by yarney
Willie try some auto parts shops some do sell pro ma stuff
Jan
Posted: Fri Jul 21, 2006 5:27 pm
by Suby Wan Kenobi
Turbo injectors have a red ring on the base of them and NA ones are grey
Posted: Fri Jul 21, 2006 5:47 pm
by Suby Wan Kenobi
Subaman has experimented with using oven cleaner to solve the problem of a sticky injector, this was done with the injectors out on the bench. The difference was noticed after reinstalling them.
Posted: Sat Jul 22, 2006 10:44 pm
by subanator
Suby Wan Kenobi, got a set of "RX turbo" injectors today.
My car is found with 1x red ring one and 3x grey ring one. Hopefully this will be the fix for my problem, thanks for the tip. :D
Posted: Mon Jul 31, 2006 2:42 pm
by Subyroo
Suby Wan Kenobi wrote:Subaman has experimented with using oven cleaner to solve the problem of a sticky injector, this was done with the injectors out on the bench. The difference was noticed after reinstalling them.
Always wondered what that "burnt chicken" smell was around Caboolture now I know :-)
The Subaru "Top End Cleaner" makes a huge difference to the way it runs, mine goes like rocket after it has this put through it on a Service at Brendale Subaru.
