what could be wrong?-[b]conversion no longer happening[/b]
chubby37
Post by chubby37 » Sat Jun 24, 2006 11:49 am
fitted up the import loom but still wierd stuff happening..headlights come on when battery is connected ....no power to windows????...driving me nuts
chubby37
Post by chubby37 » Tue Jun 27, 2006 6:48 pm
i,m open to any thoughts on the matter
chubby37
Post by chubby37 » Tue Jun 27, 2006 7:19 pm
Chris_Rogers
Post by Chris_Rogers » Tue Jun 27, 2006 8:09 pm
does the column switch match the loom? had this one a while back.
Audio Express
1987 HR31 Nissan skyline
1990 R32 Nissan Skyline GTS4
chubby37
Post by chubby37 » Tue Jun 27, 2006 10:02 pm
i,m starting to think it may not....is there a way around it????a re-wire
chubby37
Post by chubby37 » Tue Jun 27, 2006 10:17 pm
ok i just went and tested it...when i plug in the big colum plug the lights come on and there is a clicking sound near the ignition key???sounds to be comming from the ignition itself...that cant be normal can it?
Subaman
Post by Subaman » Wed Jun 28, 2006 10:42 am
I think you have stuffed another loom Bill
Chris_Rogers
Post by Chris_Rogers » Wed Jun 28, 2006 11:02 am
nope. pull the battery off and plug the column harness together, note the wires that run though the plug, one or two will not match up. 'IF' I get time I'll pop by on my way out to mums and have a squiz.
Audio Express
Post by Gannon » Wed Jun 28, 2006 6:52 pm
Hey Bill
Did you have any luck with those diagrams.
That clicking is the headlight relays under the dash.
Im thinking that there is a mix-match of connectors
Now, apon looking at the diagram, it appears that there should always be 12v at the lights, and it is the negative side of the light that is grounded by the headlight switch.
Ok, therefore,.. The white/black wire that comes from the green fusable link goes to the relays under the dash.... from the relays, a black/red and a black/yellow wire (one from each realy) go to the fuse box and fuses 7 and 8 respectively.... From the fuses, a red/blue wire and a red wire go to the common terminal of the lights.
There is only power at this common treminal when the ignition is on. so if there is power when the ignition is off, there is a problem in the control circuit of the relays.
But the lights should only come on when they are grounded by the lights switch. So its probably a mismatch of connectors
Hope this makes sense, ask any question and i will be happy to anwser it.
chubby37
Post by chubby37 » Wed Jun 28, 2006 11:59 pm
Subaman wrote:I think you have stuffed another loom Bill
the wire cutters were not at any time near the loom....this time..... :P :P
thanks chris that would be awsome....i,m not good on wires which i think my other effort shows.. :oops: ...but this time i think it is a missmatch in the plug some place but i just cant see it
chubby37
Post by chubby37 » Fri Jun 30, 2006 5:38 pm
found a way to fix wiring problem......put a tarp over the bugger and forget it,s there........eather that or burn it....if i ignor it it may go away with any luck
Subaman
Post by Subaman » Fri Jun 30, 2006 6:41 pm
Just letting you know that that coment was courtesy of Dave (mooty) when he was at my machine.
chubby37
Post by chubby37 » Fri Jun 30, 2006 6:42 pm
:D :D :D
_curlie_
re lights
Post by _curlie_ » Fri Jun 30, 2006 7:22 pm
Suparoo wrote: .
from memory when i tracecd the black/white from the green fuseable link it went straight to the fues box and was connected to the lower side of the left headlight fuse. it did not go to a relay
and the right headlight fuse had no wire at all on the lower side of the fuse box
89 L series 14"rims 27x8½" tyres, 2" lift kit,
EJ 22 motor,
chubby37
Post by chubby37 » Fri Jun 30, 2006 7:33 pm
i really dont know my a** from my elbow when it comes to wiring......diagrams are great but not for some one as dumb as me with auto elects
chubby37
Post by chubby37 » Fri Jun 30, 2006 7:56 pm
oh well.....the conversion has been cancelled.....got as far as my knowage could take me but i now have to call it quits....cant finish it so have covered it and will let it sit.....pitty but there comes a time to admitt your beaten
chubby37
Post by chubby37 » Sat Jul 01, 2006 7:02 pm
had another look today at the car.......conversion is off.....dont know what i,ll do with it yet
Outback bloke
Post by Outback bloke » Sun Jul 02, 2006 6:38 pm
What exactly is it you have done or are trying to do? What looms? What models?
chubby37
Post by chubby37 » Sun Jul 02, 2006 6:43 pm
i got an 86 turbo wagon loom from N.Z and changed it all appartfrom the dash switches and ignition......the lights come on without anything turned on and without the key in the car.....i,m not getting power to windows....and the stated clicks but wont turn over
Post by Gannon » Sun Jul 02, 2006 6:45 pm
Dont give up mate
There has to be somebody close by that could lend a hand
I rekon that your problem could be as simple as a connector mismatch
Best of luck
