Ea82t engine wiring>where does it go?
Posted: Fri Jun 23, 2006 7:29 pm
by wrx_nut
what do these connect to on the engine harness of an ea82t?
it plugs in near the battery and goes to the coil, is earthed to the back of the motor and plugs into a plug fixed to the motor...where do the connectors go?
^shows earth wire and fixed plug^
any help would be great
:D
Posted: Sat Jun 24, 2006 5:32 am
by Bratgeebah
They connect to the inside of the distributor.
Posted: Sat Jun 24, 2006 8:12 am
by Craigus
The plug on the top of the engine is the knock sensor. The four spade terminals connect to four corresponding points on the turbo distributor - they have to be in the right sequence to work, of course.
Posted: Sat Jun 24, 2006 9:35 am
by wrx_nut
thanks guys...thinking about it it was quite obious with the lug to go on the side of the dizzy.....
thanks heps :D
conversion is slowly getting there :)
