dent removal..
Dean.nabbe
dent removal..
Post by Dean.nabbe » Fri Jul 18, 2014 8:52 pm
does anyone know any tricks to removing dents from the tailgate of a brumby???
i have a dent(about fist size) just above the crease on the left side... apart from this one dent, the tailgate is in great condition.
is it easier to try push it out from the inside, or put a self tapper, pull the dent out and patch the hole?
1987 Brumby.
still to come:
2"exhaust
winch bar
Riveted ...
Post by Bantum » Fri Jul 18, 2014 10:32 pm
If you can get to the back side of it, yes try and push it out.
Don't drill holes - just makes more work for yourself.
The pros use a spot welded rivet to 'pull' on, much neater & easier to work with :
Have you got a welder ? or you could try here : http://www.eastwood.com/stud-welder-den ... stem.html#
Cheers, Bantum ...
Dean.nabbe
Post by Dean.nabbe » Fri Jul 18, 2014 11:08 pm
i don't have a welder, but i have to patch up the holes from the old tonneau cleats any way.. so another little hole will be no big deal
1987 Brumby.
still to come:
2"exhaust
winch bar
Post by Bantum » Fri Jul 18, 2014 11:18 pm
I'd get the holes welded up, much more solid than flaky bog ... :p
Ciao, Bantum ...
Post by Silverbullet » Sat Jul 19, 2014 12:13 am
Bantum wrote:I'd get the holes welded up, much more solid than flaky bog ... :p
Ciao, Bantum ...
+1
Body filler isn't meant to fill holes like that, if it doesn't fall off it will create a water trap on the inside and rust eventually. But then welding them successfully requires a different skill.
Post by steptoe » Sat Jul 19, 2014 8:13 am
i had a pretty smart old painter do my fork lift incident with a similar device that spot welded copper washers to the panel, hooked and pulled on them until peferect :)
Dean.nabbe
Post by Dean.nabbe » Sat Jul 19, 2014 12:34 pm
i'm gonna sand the tonneau cleat holes, then dent them in a bit with a punch to give me something for the filler to grab on to... i wish i had the means to weld them, but it's just not my available means atm.. bog will have to do for now.
1987 Brumby.
still to come:
2"exhaust
winch bar
