Brumby thermo fan
Brumby thermo fan
Just wondering if anyone knows at what temp the thermo in the brumbys kicks in, the other day the car got to just above the half way line on the temp gauge and the fan still hadn't started, in fact I've never seen it run. Would it or the sender be faulty or has the car just not gotten hot enough?
- littlewhiteute
- Silverbullet
Probably the sender in the bottom of the radiator (on the drivers side) has a single yellow wire coming from it. My fan in the ute used to kick in...until I swapped engines and radiator and forgot to switch over the thermo switch, now I can't be bothered draining the rad just to change it
- subarooster
Those temp switches give trouble a fair bit. Good way to check that your wiring/ relay/ thermofan are all in working order is to just take the yellow wire off the sender and earth it out ( touch it on the closest metal component that it will reach) and if your thermo fan kicks in then it is most likely going to be your sender. Also check to see that the little earth loop is connected onto the top of the radiator to your radiator support. Shouldn't need it but have seen the radiator not be earthed before because rubber mounted.
See how you go.
See how you go.
01' Liberty B4.
- Bantum
Fans ...
Mine has dual fans for air con, the first comes on after engine has warmed up, just under half on temp, the second one usually kicks in when the temp gets a bit above half way...
P.S. - There is also a relay that controls all the fans, Air con etc. on the Drivers side that can fail / burn out - you should check it also to make sure its working ...
Cheers, Bantum ...
Cheers, Bantum ...
