ej22 problem
mrmattyking
ej22 problem
Post by mrmattyking » Sun Jul 29, 2012 10:13 am
Having trouble with Ej22 loosing power under load.
Seems to idle ok and will rev nicely if throttle on gradual. but if throtle is not on gradually it gets bogged down and looses power and wont rev out,
The only ECU code being thrown is purge canister solenoid (had that same code before with the last ej22 installed in same car and that ran fine)
I have tried swapping all the sensors with ones off my last engine which was running sweet.
Also tried changing coil packs, leads and new plugs.
Anybody had this issue before?
any help much appreciated.
Post by steptoe » Sun Jul 29, 2012 10:19 pm
afm issue or air leaks into ducting after afm ? a hose off somewhere?
Post by RSR 555 » Mon Jul 30, 2012 9:55 pm
steptoe wrote:afm issue or air leaks into ducting after afm ? a hose off somewhere?
I too agree that there is a pipe off. I suspect the one that goes to the IACV. If you could post some pics of your setup that may help.
mrmattyking
Post by mrmattyking » Tue Jul 31, 2012 8:06 pm
Thanks for the replies,
Just checked, looks like all the pipes are on including IACV hose. pretty sure all in correct place.
I'll attach pics, you may be able to see the problem.
CheersImage
Post by TOONGA » Tue Jul 31, 2012 8:29 pm
all the pipes are on but one of the plastic fittings on the intake to the throttle body appears to be broken. Hard to tell with the resolution of the image.
I did circle it though
hope this helps
mrmattyking
Post by mrmattyking » Tue Jul 31, 2012 10:20 pm
Hey Toonga, yeah your dead right mate, that plastic connection piece you circled had busted off.
I knew it was broken but i thought it was just a hose joint connection and didn't realise it actually fed into the intake as well !!
Thanks for taking the time to check it out, You did very well to pick that up, thanks heaps.
I have now swapped the intake with a spare, Will test in the morning, Im pretty sure it will fix the problem.
a Massive thanks for the help guys.
Matt
Post by RSR 555 » Sun Aug 05, 2012 9:57 am
Was this the problem? as it didn't look like the break was through the main intake pipe, only the holder piece for the tee pipe for your beathers.
Post by El_Freddo » Sun Aug 05, 2012 10:54 am
Paul, I thought that this was a pipe that fed into the intake rather than just a T piece for the pipes that are connected to it?
I too am keen to hear what the outcome of the new intake is.
Post by RSR 555 » Sun Aug 05, 2012 12:20 pm
If hooked up correctly, the left and right rocker cover breathers will joint the top of the tee and the bottom of the tee should go back and join the intake pipe further back towards the air filter box. If you have a spare one of these pipes, just turn it upside down and you'll see.
