EJ 22 Surging under heavy acceleration
libertymal
Post by libertymal » Mon Apr 30, 2012 7:20 pm
Hi all, im fairly new to the forums but am currently having a problem with my gen 1 liberty. It appears to be surging quite violently when i accelerate over 75%. now the obvious answer to this question is to not nail it but i was hoping someone could please spread a bit of light on the situation for me. i am a mechanic and it looks very much like a tps related problem but you guys are the experts.
shuffbag
Post by shuffbag » Mon Apr 30, 2012 9:24 pm
i'll be keeping a eye on this. might help me...
libertymal
Post by libertymal » Mon Apr 30, 2012 9:58 pm
good. u feel my pain. haha:p
Post by El_Freddo » Mon Apr 30, 2012 10:10 pm
Also check your fuel pressure. If this is not steady under load it'll cause some issues with smooth operation - and it can be difficult to track down until you're left with no other options.
I'll be keen to know what it is so I can keep an eye out for it. I've had an issue before that was resolved with a new knock sensor, temp sensor and a cleaned up TPS (correctly adjusted once installed).
Have you checked your codes yet? Find the two black connectors in the panel above the driver's feet, connect these then turn the ignition to the on position.
Count the long flashes then the short - long flashes are a 10 value, a single flash is a 1 in value. Add these up and it will give you a code. For example three long flashes and 2 short flashes is code 32.
This link should help you work out what your codes are.
And this is what I went through:
http://youtu.be/aLxO4ETlk9c
libertymal
Post by libertymal » Tue May 01, 2012 7:00 am
thanks for the great insite. ive always wondered about the fault codes.... ill go and check this now.
libertymal
Post by libertymal » Tue May 01, 2012 7:08 am
good....only
21
22
23
31
32
haha and i thought i had something to worry about.
woody.t
Post by woody.t » Tue May 01, 2012 10:50 am
21-coolant Temperature Sensor or Circuit
22-Knock Sensor or Circuit
23-Air Flow Meter or Circuit
31-Throttle Position Sensor or Circuit
32-Oxygen Sensor or Circuit
bit of a list to deal with...
to do list:
Post by RSR 555 » Thu May 10, 2012 12:33 am
Hi and Welcome libertymal,
Can I suggest you clear the codes in history and go for a good hard drive again, then recheck. I suspect someone was unpluging things when they were trying to fault find.
How did you get these codes? was it from the green or black plugs?? and do you have the manual to follow on clearing the codes???
