Hi there fellow board members. Yes it has been a while since I have checked in. Hope there are some familiar names still using the forum. Other less enjoyable things, like home maintenance, have been sucking my money and time.
To refresh.....had a twin carb ea 81 motor with the d- shaped twin siamese exhaust ports fully rebuilt. Has had a "flat spot" on hard right hand turns from the start. Otherwise has been running very well. Now done 5000 km. Borrowed a compressor and have blown out all fuel lines; replaced fuel filter; fuel pump appears to be have no problems. Installed an electronic dizzy with the rebuild but had to set it way off the timing marks to get it to run. Decided to go back to the old points dizzy today. No improvement, except that the timing marks line up again.
Sprayed some carby cleaner around and it almost stalled when I blew it near the throttle shafts. Any thoughts...can these be replaced or rebushed? The shaft between the two carbys that the accelerator cable connects to, which then accuates the throttle shafts also has a fair bit of play in it.
What do you reckon.....
Long time, no use forum.
- hughybabes
1984 sportswagon
ea81 twin carburettor motor.
"d-shaped" siamese exhaust port heads.
mild low torque cam. electronic dizzy.
2.5 inch engine pipes; 2.25 tail pipe; rear sports muffler.
- schultzie
Welcome back, i have spotted you a few time in the last couple weeks, well i think i have any way... been seing a really nice My around so yeah, still havent seen it since the new donk going in, (i have an l series now) and the MY got wrote off... all the gear is FS as well,
the play in the linkages couldnt be any good might explain something.. you should be able to get the bushes and or a carby kit for it,
Justin Schulz...
and some of the names have changed tasbrat is now brumbretty ther eis more but i cant recall them now
Justin Schulz...
