indicator problems
woody.t
indicator problems
Post by woody.t » Thu Nov 25, 2010 11:44 pm
hi,
sister came home from work today and said none of her indicators are working, hazards work and all fuses are fine but nothing happens when using the indicator stick .. . . any ideas it's a gen 2 outback so has airbag and shit so i wasn't to keen on pulling the steering wheel off
cheers
to do list:
d_generate
Post by d_generate » Fri Nov 26, 2010 12:25 am
Get some "contact spray" and give it a good going over without taking it off, usually just mucky contacts.
Post by RSR 555 » Fri Nov 26, 2010 3:15 am
Does it have an aftermarket immobilizer/alarm? sometimes these play havoc on the indicators. I'd also check the connection from the combo switch to loom.. under the dash near the steering column. If you're unsure (due to airbag stuff) then call Paul from Nicol Auto Electrix on 0418 950 097. He is mobile (southern side) and prices are fair.. tell him you know Paul from RSR Performance and he'll look after you.
