Liberty cutting in and out
Posted: Sun Oct 10, 2010 4:10 pm
by MUNKEY
Intermitting problem that i cant diaognose. Ill be driving along and it cuts in and out quickly as if im switching the key on and off again. happens once or twice every drive.
Ive cleaned the battery terminals and put the back on tight. I checked and cleaned the air flow meter. And ive had the car running and have shaken all the wiring under the bonnet trying to see if it will cut but it doesnt. the car is bog stock and one a owner with no after market accesories on it that might be causing an electrical problem.
Any ideas???..
Posted: Sun Oct 10, 2010 10:08 pm
by 90brumby
does it have a aftermarket immobilser also next time it does do it does the ignition it self turn off
Posted: Sun Oct 10, 2010 10:09 pm
by sven '2'
Fuel filters x2
Posted: Thu Nov 18, 2010 9:15 pm
by 69terra69
hey mate my car does the same thing i got i liberty 92 auto do you find out whats wrong with it ??
cheers james
Posted: Thu Nov 18, 2010 9:41 pm
by olddog642
Okay it sounds like it could be your fuel filters are blocked just enough to restrict the volume of fuel being delivered.
Hylton:twisted:
Posted: Thu Nov 18, 2010 11:39 pm
by 69terra69
all fixed a put a different airflow meter in that i had on my wrecking car and works fine now. :)
