Low RPM Miss
Posted: Thu Sep 30, 2010 3:43 pm
Hello.
We'll my newly acquired '90 Brumby has some issues that I would like your assistance in fixing (hence user name!). I'll do threads as I go, to separate the issues.
First things First. She is a bog stock standard '90 Agquip Brumby (any diff between ag and non ag?). The old girl runs perfect (as much as an old car can!) but 15-20min into driving she will develop a low RPM & low throttle miss.
Now, google has revealed that the fuel line is prone to becoming blocked pre pump. I haven't checked it, but it doesn't sound like the problem.Why?
1.While engine is coughing and surging in the lower RPM with light throttle (ie puling away from lights) if I put the foot down the engine will pull cleanly and without hesitation!
2. If it was a blocked fuel line, it would normally restrict fuel flow. Causing a lean or fuel starvation moment. I would assume that this would happen when there is a max load situation. ie going up a hill. But this only happens under light load/RPM situations. Strange
3. It seems as the engine reaches normal operating temp it is more likely to occur. If it's running fine, but the engine is near normal temp, and I stop for a short time (fuel stop) it will almost always start missing. Almost like heat is causing something to happen. I was thinking maybe coil getting heat soak?
4. The problem comes and goes. It is always fine when starting the engine cold. Then will start missing 15min or so into the trip. Then after some time it will stop, then return again later. Bloody annoying!
I don't want to start replacing things trying to fix it, so if you have a suggestion please tell.
Thanks
Thanks
