Brumby exhaust steam up
Posted: Thu Aug 19, 2010 8:00 pm
by Brrrummmbeee
The little EA81 is pumping gaseous coolant out the exhaust. No oil in coolant or vice versa. Before I tear a head off any ideas on what else to look out for? She's running on 3 & 1/2 cylinders, LHS bank methinks is down.
LP
Posted: Thu Aug 19, 2010 8:39 pm
by RSR 555
Inlet manifold gaskets
Posted: Thu Aug 19, 2010 9:36 pm
by maxxair
head gasket, try putting 'metalic seal up' into the radiator. hopefully this will stop it, until next time you overheat it, that is
Posted: Fri Aug 20, 2010 1:35 pm
by Brrrummmbeee
I'll try the inlet manifold gaskets, and failing that maybe add sealant..
Thanks,
LP
Posted: Fri Aug 20, 2010 7:23 pm
Its not a wet spark plug again when climbing hills is it??
I'm hoping its what RSR said ^
