Being LPG fed there is not much control the ECU has over functioning, but there is the knock control module still relied upon. The good Eagle performance leads , Bosch cap and rotor have 50,000km on them, 3 NGK plugs have about 22,000 km and the other about 15,000 (lower compression and oils up) old donk of about 250,000 blows a little weed under hard acceleration and medium vacuum down mountains and the drive off after the descent blows much weed for a moment or two (better under BOOST) LPG more sensitive to poor sparks. Might be time to at least inspect the cap and rotor and replace plugs or at least #2 again or keep screw driver, torch and spare ignition module.
Not going to blame the LPG equipment, but maybe worth a look.
The last time I got something like this it was a corroded FL fusible link that caused great dramas - better check them too
Keep you informed
