Can't see the logic in this scenario !
Posted: Fri Feb 24, 2006 1:43 pm
Here is the scenario:
1982 subie wagon humming along nicely until one day on a dort road we got a flat. Put on the spare and noticed that the brakes started to get a bit of vibration when stopping that went up through the peddel and the steering. Seemed like the front somewhere. It got progressively worse but there was no wobble while driving. Put on the handbrake hard and we get a clean sure stop, no vibration. It got so bad we were afraid to drive the vehicle.
Talked to the local mechanic and he even had a quick drive and said it was the front, probably the disks. (but the handbrakes work fine even at 100kmph) ?
After numerous input I ripped the front end apart and sent off the disks for machining, put new brearings in both F hubs, and checked all the brake system and front end.
Put it all back togeather and and and and No change ! %&%^$&%^&
I could not see how it was going to be a rear end problem but as there was nothing else to do I first swapped the spare tyre off the rear and put the repaired one on the back. Now it goes like a dream and no vibration. Yep, should have tried that earlier.
But, why does a rear wheel cause very heavy brake vibration in the steering and peddle. Wheel nuts cranked and you get no problems driving, only when you brake.
I can not see the logic here, anyone encoutered this before or have an explanation ?
