Brumby problems
Callum89
Brumby problems
Post by Callum89 » Sun Oct 18, 2009 5:44 pm
hello, after my 5 speed conversion the clutch cable snapped right behind the clutch cable. was wondering if i hooked it up wrong for that to happen? Also I was wonderin if anyone has a picture of the welding needed to join the L series gearbox leavers to the brumby 4wd lever? Lastly i was wondering how much difference in speed an gearage, when you put 14" sunraysiers on?
Cheers Callum
Post by El_Freddo » Sun Oct 18, 2009 5:56 pm
Callum89 wrote: Lastly i was wondering how much difference in speed an gearage, when you put 14" sunraysiers on?
Depends on what size rubber you're using:
175/70 on a 13 inch rim is the same diametre as 175/60 on a 14 inch rim... (I think I've got that the right way round!)
Callum89
Post by Callum89 » Sun Oct 18, 2009 6:08 pm
Cheers Bennie! It would smarten it up a bit! :-) Will have to find them now!
Post by steptoe » Sun Oct 18, 2009 7:23 pm
don't cut or weld the levers unless you want to retain Brumby console. I left 5 speed box as it was and fitted the better L series console, all it leaves is a 10mm gap between console and the radio console of your Brumby. I also run 14 inch sunnie with 185 or 175's and speedo is closer to being spot on than when it was with 13"s. checked against many GPS units
Callum89
Post by Callum89 » Sun Oct 18, 2009 9:14 pm
Oh ok then steptoe! I just want to make it more friendly to the eye and make it look more legal. Cheers for the info it is always welcome!
